Iv been trying to findout what brand exhaust this is, i know its a brand because i have seen one other skyline with this exact same exhaust. The pix of the plate says Jasma, SR and For road car. I know that jasma isnt the brand as they are the emissions control people. It has a jasma member number listed on it too let me know if it would help.
Thanks
https://www.sau.com.au/forums/topic/69535-identify-this-exhaust/
It may not be quiet now for the simple fact that HKS don't used stainless steel packing in their exhausts. It is a mild steel and once this wears out, it makes the exhausts rather noisy. Don't foget, the exhaust has probably been on the car for the time you've owned it, + another 3-5 years.
Mine is a Trust exhaust, and doesn't have Trust anywhere on it except on the v-bands between sections. None of the piping itself has any "Trust" markings, nor does the rear cannon
Ultimately I guess they all come out of the same factory in Japan.
:P
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
