I dono why'd you give up the a31 front end though... maybe for a 180 front..
There was a s14 fronted cef posted up in this section some time ago now and I think most people didn't like it. I reckon it could be ok but if anyone finds photos please post front and back and side if possible.. It's pointless seeing a s15 fronted cef when it just looks like a s15 from the front :)
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289194
hahaha that laufiro is about as NZ as they come, matt black paint, workshopX frontbar
call me the biggest playahater ever but the front fender doesn't link up to the rest of the panel work properly ie: the "a" pillar
not usually a big concern but this could cause rust if not sealed properly when rain leaks through those cracks, laurel and cefiro fenders are notorious for rust apparatnly
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289215
you mean like an N13 pulsar front bolted onto a brandnew nissan pathfinder?
or or what about an 80's CA nissan EXA bolted onto a le man's nissan R390 race car?
the possiblities are endless... simply endless...
They all sound good to me, but why not swap it around, bolt a Pathfinder front to a N13 pulsar? :)
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289263
Anything R34 is pretty horn IMHO, I want a R34 kit for my R32 like this one at Garage-13:
Click for full-size
But since it's "from $4490" kinda hard to justify on a car not worth much more than double that, factor in re-spray and i think it'd only be worth it on a R32 GTR.
But i can dream. *sigh*
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1289437
roflmao garage-13's R324
its made by Bee-R and I think that's garage-13's pipedream for suckering someone into buying the original so they can copy it.
and the R34 on R33 unit they sell is a URAS one.
https://www.sau.com.au/forums/topic/69616-s15-fronted-a31s/#findComment-1291012
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
