Need 10 people to qualify this group buy of oil catch can kits.
Comes with:
- 15mm or 12mm hose (1.2m) - please specify.
- hose clamps
- filter
- 800ml
- Unbaffled but can be easily done with steel wool and a stocking (SK handy tip number 1954) :cheers:
Usefull installation links - click here - and here - and here
Price for 10 buyers - $80 delivered (Australia only)
Closing - Wednesday 20th April. Payment due Friday 22nd April.
1/ 400kwgtr_____________ - PAID - SENT
2/ Gizmo73______________ - AWAITING PAYMENT
3/ Abo Bob______________ - PAID - SENT
4/ (B1) MR_fanny_________ - PAID - SENT
5/ aussnick______________ - PAID - SENT
6/ [[d a n n y]]___________ - PAID - SENT
7/ gtrGhosTDoGG11_______ - PAID - SENT
8/ GIGOLO______________ - PAID - SENT
9/ voona________________ - AWAITING PAYMENT
10/ damuscat____________ - PAID - SENT
11/ C & B________________ - AWAITING PAYMENT
12/ BLakniTE x2___________ - PAID (2) - SENT (2)
13/ tkch55 x2_____________ - PAID (2) - SENT (2)
14/ nismo_au_____________ - PAID - SENT
15/ lwells________________ - PAID - SENT
16/ Yotis_________________ - PAID - SENT
17/ stu_r30_______________ - AWAITING PAYMENT
https://www.sau.com.au/forums/topic/69665-oil-catch-can-kits/
  • Replies 94
yowser...
Im also in..nice price..
Just to confirm for all - these ones dont need to be cut open/welded again to install baffling...they have access via a lid, etc etc...
Based on the threads about this going around, im sure this wouldve been asked eventually !!
The filter can be taken off for the plumb back set-up.
The opening for the filter is just big enough to feed the stocking in and then stuff it with steel wool. I used a wooden skewer to help feed the steel wool in.
How big is the opening where the filter is? Does it have a thread? What can you use to close it off?
Also, the 2 inlet/outlets, do they finish with the wall of the can or they lead a bit inside?
Sorry about all the questions but I got a dodgy one recently. :D
Top opening = 9mm inner diameter
No thread but has lip for hose clamp.
You could use a bung or a peice of hose with a bolt and hose clamp to close it off.
2 inlet/outlets finish with the wall of the can.
Yeh ill take 1 for 80 bux ;)
Count me in, PM me for more details please
Alright! 9 out of 10 already. :)
I will PM everyone with payment details as soon as we get the 10th buyer.
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
