Read their policy on refunds... it is on the website.. I think they are quite good, I am waiting for thema t the moment to respond to a quote request, In the last two months I ahve put about 1k through them and will be doing another 2-3k over the coming 3 months..
https://www.sau.com.au/forums/topic/69718-nengun-com/#findComment-1289789
Brent is good to deal with,Nengun are improving there site all the time.You will have no problems. Also try Greenline motor sports, they are also decent. you will find the prices from both business a lot more realistic than here in aust.
https://www.sau.com.au/forums/topic/69718-nengun-com/#findComment-1289857
I have order the suspension from them, they shipping it to me on 01/04/05. It is my first time to order parts from them. they said it will take 7-21 working days. See how does it go, I will keep on update once I receive the suspension. To give u an idea. But yeh, the price are realli good. After plus TAX, it still can save a lot of money.
https://www.sau.com.au/forums/topic/69718-nengun-com/#findComment-1289864
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
