Guys, i was wondering if any1 knows how to tell the difference between a 2.5L and 2L gts ?
besides driving it(i wouldnt know since ive never driven a manual nor a powerful car). is there any other alternatives ?
i worried about this becoz i dont want the dealer to be swapping plastic covers, plates etc inorder to fake a 2.5L.
thnx guys
you couls drop something into the bore through the sparkplug hole and find bottom dead center then measure the stroke to top dead centre. Look up this website for the stroke of the two engines and work out which one it is.
Or you could take it for a test drive and give it everything it's got, if it doesn't make any power until over 4000rpm but keeps going till close to 8000rpm(mine stops at 8500) then it's an rb20(and it sounds shit hot doin it) If it makes power under 3000rpm and pulls the shute at 6500 whilst sounding like an angry bastard it's probulary an RB25.
Hope that help
RANT!!! for fark sake.. and you guys call your self skyline driver!!!
shame on you...
ok here you are.. this will explain it all
http://zhome.com/rnt/RBEng/Chong.htm
cheers
Joe
u made my day :D
ohhh hang on. since the rb20de is like a camry engine(no power). i dont think u can import it under sevs eh ?
ohh, so i have nothing to worry about., yaay. :)
you can't import either from memory (RB25DE is just under as well).
the RB20DE is a top feed injector setup, wheras the RB25DE's a side feed. Most RB25DE's have VVT, so they'll have a lump where on an RB20DE it says "RB20".
r34_skyline - Just out of interest sake are you talking about an R34? As visually the RB20DE and RB25DE are very similar, I noticed you mentioned swapping plastic engine covers, which would only apply to R34's
Can't believe no-one has said this already, check the factory VIN plate:
HR34/HR33/HR32 = 2.0L
ER34/ER33/ER32 = 2.5L
Thus H = 2.0L, E = 2.5L. Note that there may be other letters between the H/E and the R, these denote things like HICAS etc.
This of course assumes that the engine hasn't been changed from the factory......
yes, exactly.
as u can see, i abit worried about this issue. i dont wanna end up with a 2L wannabe.
im gettin if from a dealer. im hoping they dont try any funny business.
i thought HR stands for 4 door ? mmm, guess im wrong.
If you have a careful look at this the RB25 doesn't have the Air Jet Swirl Valve actuator and solenoid found on the intake manifold runners...looks like the RB20 doesn't have a Auxilary Fan on the radiator either.
And the car will be VERY sluggish to drive, much like an old corolla :rofl:
I've heard of a few of the RB20's knocking around down south, so it pays to check thoroughly.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
