I have just installed an Apexi Super Suction with super intake air filer to my stagea. To fit I had to take the radiator overflow catch tank out, and have a temperary one for now. Have other people had the same problem? Does anyone know what I could replace it with. I measured 3/4L that it needs so I need to find a small one that can fit somewhere .
What have other people done/used?
I will have to enclose the POD at some stage for more cooler air.
You shoulda just bought the rampod by itself. It just bolts omto your airflow meter. I have one. I'm gonna buy a carbonfibre box for it to sit in.
You can easily make one yourself. Use cardboard to stencil it first, then get hold of some 3-5mm alluminum and cut and bent to shape. To join the lid to the sides (and sides to body) you can use L-brackets with a bolt and threaded hole.
PS: You only need to make 2 sides and this could be done out of one alluminum piece. The other 2 side are formed by the car body.
Note: A pre-fabricated air box my not be suitable, as they are designed for one type of air pod, thus you may have to modifiy it to fit. DO NOT ATTEMPT TO MODIFY CARBIN FIBRE.
(Unable to take better pictures as my car is currently at the paint shop)
I think will look at buying a smaller plastic overflow tank from nissan first, if not then i'll do what Al said and make a custom one.
Also I am going to swap my air intake snorkel and replace it with a GTR one as it is wider and closer to the front and edge of engine bay so it will be right near my air filter. Ill have pics in a few weeks.
Emanuelt....
I love that duct. I'm trying to do a section in the standard duct at the monent.....
Are you using your standard duct anymore?? Can I borrow/buy it from you?
I need a prototype to play with.
  • 1 month later...
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
