Steve,
My thoughts exactly, what made me think there was a restriction some where in the exhaust is the way the curve flattens out in the top end on the high boost setting.
The power curve can be influenced by the ramp rate a little, but it still looks a little slow getting on to decent boost.
As discopotato once said with this dyno graph... Pumping losses.
  • Replies 159
how can yours fry the tyres, when mine makes the same power and everything, 200rpm later is the only difference and i have not one problem with traction. ??
Judging by your nick, youve got a R31. Maybe they have a softer independant rear end than the 33 or much stickier tyres The 33 is slippery, even i get sideways movement in second once i come on boost with a 2530. Count yourself lucky you dont have these issues. First gear is useless. Ive converted back to stock suspension to get some more grip.
HICAS, too high rear spring rate, poor suspension geometry, too stiff/poorly valved rear shocks, worn sub frame bushes, too high tyre pressure......etc
:D
first gear is fine, unless im saveage on a launch. If i am smooth then its totally fine unless im nasty with 1st/2nd gear change then its skating
My rear end is more prone too loose traction than an R33 due to the primative design of the R31 IRS
Ask any coupe owner than tries to get grip, its a mission due too squat and the sheer camber that ends up on the rear causes around 2/3 of the tyre to actually touch the road.
And im only running 245's on the rear, just cheap sumitomo's that in my opinion are very average. Thats on 18's too...
I agree with you SK, some of these guys cars must be shockingly setup as i wouldnt even say my setup is anywhere near what i could be.
still, im at a loss :headspin:
Maybe you dont have the power you think you have then. What Sumitomos you running, im running the HRZ 11, 255/40/17.
So many variables. I spent alot of time and money setting up my skyline so it didnt do crazy things.
R31 - non IRS too isnt it? IRS has its own challenges. Just being non IRS and no HICAS would give a car massive advantages until you sorted the issues in a car that is equipped with IRS and HICAS.
Making the power is only half the job IMHO.
Sorry forgot to add, just because two cars make the same peak power, run the same boost and come onto boost around the same rpm, doesnt mean they have the same power over the rev range.
Car A at 1 bar may be making 250rwkw @ 4000rpm, car B may only be making 180rwkw at the same rpm and boost. Both may make 300rwkw peak power. The shape of the curve makes a big difference too.
HR31 has IRS and HICAS
HICAS i still retain, and all of it is very primative.
And i have 270rwkw, there is no doubt about it. Rolls off Race Pace Dyno as such :rofl:
See what it makes next weekend @ AutoSalon... :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
