ZXR250 1990, complianced 2000
21,000kms, Grey with yellow rims
New starter motor and battery
Discs recently machined
New brake pads all round
Twin 750 front disks
Sports suspension- USD forks with adjustable preload, and adjustable rear shock
New fork seals
Sports exhaust system (very nice note!)
Recently had a new cam chain and tensioner put in and radiator flushed
New clutch cable
Clear carbon fibre indicators
Tinted screen
Tyres: Bridgestone Battleaxe with plenty of tread
2-3 years ago: New clutch, sprocket and chain
Motul 5100 fully synthetic oil used, and only use BP ultimate fuel
Reciepts for most work done
Very good condition
Selling due to purchase of show bike.
Very Cheap for a 250 of this quality, wont find many better.
9 months reg, COMES with RWC- Was $5200!! NOW $4,200 FIRM!
Melbourne
call 0405 735 242 or PM any questions.
https://www.sau.com.au/forums/topic/70024-kawasaki-ninja-zxr250-1990/
  • 5 weeks later...
The bikes a 4 stoke, runs on unleaded, and goes really well. If you want, you can get somone with a licence to test ride it. It has the handling of a sports bike, and feels very quick for a 250.
Cheers.
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
