i got quoeted $291ea. tyre 225x50x16 on my stock gtst rims. sum 3000 brand tyres.
 thats fitted n balanced by the way. Beaurepairs
For that much they'd want to be some pretty damned good tyres, I suggest you shop around, you should be able to get good (not excellent) rubber for half that amount.
The Hankook Ventus K104's seem to have a good rep. as bargain quality tyres and people are picking up 235/45/17 for around $180.
They will fit, as in bolt on, but they're no good as the offsets will be all wrong.
I had R32 GT-R rims on my R32 GTS-T with 225/50/16's and they fitted great.
( I then got my gaurds rolled and now have 17 x 8 front with 235/45/17 fitted and 17 x 9 back with 255/40/17 fitted and she looks very fat indeed ).
With the GTR32 Rims having a bigger or smaller however you put it,
On a R32 gtst with stock rims you'll notice that the rims actually sit inside and under the guards, whereas for GTR32 rims the offsets are like +30 (or something from memory) so ALL for rims will sit further out from the hub and if you car is lowered with no camber your wheels will hit the arch/guards when you go over a bump or turn hard into a corner. BUT if you have standard shocks and stock ride height you won't have the Guard hitting problem.
BUT keep in mind its illegal to have your wheels sitting outside your guards, like if you stand next the side of the car where front wheel is and look straight down if you see the tyres sitting out pass the guards it illegal (or defectable).
This is my understand and STUPID/wrong offsets because i've had 2 sets of rims which didn't fit on my car PERFECTLY. BUT someone with a R32Gtst with GTR32 rims can clarify this.
R32gtst rims are 16 x 6.5" (you can fit 225/50/16 or 205/55/16)
R32GTR rims are 16 x 8" (you can fit up to 235/XX/16 maybe even a 245 dunno but standard i think is 225/50/16 compared to the 205/55/16 on gts rims)
i hope that helps. :)
my 2 cents
Going from 6" +40 to 8" +20 means:
From the Wheel Offset Calculator
The clearance from stut housing to the inside of the wheel will be 5mm LESS
The outside edge of the wheel will EXTEND an extra 45mm
Considering you want to at least TRY and keep things even, so as no to screw your suspension geometry up too bad, GTR rims don't qualify. +32 to +35 is far more suitable for 8" rims.
Ash.
Would you know if the R33 GTR rims are the same offset.
I've seen one set on a R32 GTST, they looked like they sat under the guards, only just.
Not sticky outy like the R32 GTR rims I've seen.
32 GTR rims looked illegal to myself, R33 GTR's didn't.
Doesn't mean there not illegal though.
Ash.
Hey Joel, I'm not really sure, but i *THINK* offsets are pretty much the same across GTR's and GTST's regardless of R32/33/34, what you describe could have been the fact the R33 has 17's and less "tyre bulge" than the 16's of the R32.
I think people just need to retire themselve to fact that while GTR rims will fit GTST's in most cases, it doesn't mean they're correct or such a great idea handling wise, regardless of whether or not they're legal. Sorry.
Ive got 16" rims on mine....
the rears are 8" wide with 225/50/16 (offset is +38)
the fronts are 7.5" wide with 225/50/16 (offset is +25), also
the car is lowered and sitting about an inch or so above the top of the tyre.
The car hasnt had a proper wheel alignment in a very long time (read camber is off) and the tyres wear on the inner side.
The tyres clear hitting the guard by about 10 to 15 mm or so, and if it were given a proper wheel align. id say it would be close, but still not hit....
  • 4 weeks later...
Hi Ash,
could you please elaborate as to why R33 GTR wheels would not be beneficial to the handling on a R32 GTS4?
is it to do with the wheel alignment now being wrong? should be easily fixable...
I just got some today but haven't had the time to fit them yet.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
