Ok.....well there has been alot of talk of swaybars in a couple of threads. Whether they fit from s13 etc. I have never got a definate answer that they do ...except for the rear. GTR Ben informed us in another thread that the front s13 doesnt fit.
Well i have emailed whiteline about whether we can get them made up . Peter from whiteline emailed back and said that we can but they need a car to model it off etc. They can just have a bar ...but they would prefer a drivable car. I am finding out how long they need it for and whether the prices will be the same etc..
Depending on how long they need the car ( have to take it to whiteline in minto) i might offer mine ....mine is a daily driver and need it to get to work...and minto is about an hours drive from me .....so could be a problem
any way this thread is just to inform u guys and see how many people might be interested. Nothing definate at the moment.
Alex
https://www.sau.com.au/forums/topic/70410-possible-swaybar-for-cefiro/
FYI
there are a few A31s in this buy I noticed as well -
http://www.nissansilvia.com/forums/index.p...showtopic=82750
Seem to be coming from Whiteline too so it might be worth investigating if we can mention to whitelines we're from the same buy - seems to make up the number nicely :)
Especially seeing that whiteline would make it up, sell it to us, and them off a car we provided.
FYI
yea saw that post and asked the guy who was organising it and trying to find out whether the s13 front swaybars fitted for it. I asked him whether they would work and he wasnt sure....and never got any extra response from him.
when i get home from work i should know how much and how long they need the car etc ...
from peterat whiteline 'G'day Alex,
Initially we would like a car for a couple of days. This will enable bar sizes/design work to be undertaken so we can produce matched bars to balance up the chassis. Any further development may be possible at a later stage dependent upon predicted production numbers etc.
Pricing would remain consistent with similar products and a Group buy price would be available for a buy of 10 or more items. '
ok so they will need a car for a few days ....too_much_boost expressed interest volunteering his car...do u still want to do this?
And if we can set a group buy then we prob can get em cheaper aswell
I can give you all a DEFINITIVE answer on this..........the S13 whiteline blade adjustable swaybars DO fit onto cefiros' and Laurels. I know this for a fact because i have fitted them myself.
I know that there has been alot of confusion as to fitment of these items.....so i decided to "bite the bullet" and purchase some whiteline swaybars and hope for the best.........it worked out i was right.
A friend of mine also removed an aftermarket swaybar from his cefiro and swapped it for an item from an S13 (front) it bolted up perfectly.
I hope this helps all of you out. Perhaps somebody could put this information as "sticky" for other cefiro/Laurel enthusiasts.?
the only thing i have been thinking about is that the s13 ones were made for the s13 ....with either ca18 or sr20 in them ....cefiros are different with a heavier eng etc .... will they perform as well.
im not too fussed on this though ...just thought i would bring it up....
Riverside.. they are not exactly the same.. and a S13 silvia bar will not fit a S13 with an RB motor.. thats where the problem is. The sump hits. With a 4 cyl motor, no problems at all!
I have pictures showing the difference if you really want me to upload them all etc.
The A31 bar from a 6 Cyl powered car has a much larger portion at the front to clear the sump.
I hope this is clear?
If someone could demo there A31 (WITH A RB MOTOR) for whiteline I would be very happy. They probably still have my spare A31 Swaybar and links.. if they havn't throw it out.
If someone is sorting something out, give me an email.
[email protected]
Thanks,
Ben
Riverside, I just looked at the other post and noted you have a RB motor.
Hmm, odd. Maybe the whiteline bars clear a little more, maybe the aussie Cefiro's are slightly different.. who knows.
My engine is also lowered 15mm so this doesn't help.
I may have another loook with the Whiteline bar. (I have a whiteline CA18 27mm adjustable front bar) maybe this is the problem. How different are the SR20 bars?
Maybe this is the problem I am having? If you have fitted a SR20 Whiteline bar to your A31 with RB motor and it fits though, I will take your work for it :P
In theory the S13 with RB SHOULD be the same as A31 with RB........but i can not confiently comment on that as i do not own an rb S13.
I have fitted the whiteline swaybars to BOTH RB and SR powered A31's and C33's.........without any issues, The RB powered A31 had the sump sitting quite close to the bar bt it did NOT touch. (I simply asked for the largest blade adjustable swaybars available for S13, so i am unsure if i have CA or SR items, i doubt the aftermarket items are different anyway)
I imagine that the lowering of your engine may be the main issue.
Thanks Riverside.
Well I know for a fact with my engine the Stock S13 bar doesn't fit with my RB engine lowered etc. The sump was resting on the bar when I installed the engine..
Maybe you have the SR20 Whiteline bar and it allows more clearance. Whiteline do supply a CA and SR S13 bar.
  • 3 weeks later...
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
