Just got my car re-tuned and dynoed and thought some people might be interested in the results, particularly the tuning of the unichip. Its a bit unfortunate that I don't have a pre-unichip dyno but I didn't own the car when it was fitted.
R34 GT-T tiptronic
Current mods are:
3.5" unknown japanese brand exhaust
3.5" unknown japanese brand dump pipe
Greddy Profec B boost controller
Blitz LM intercooler
Apexi Super Intake
Oil cooler
Unichip
The reason I got it re-tuned was because I felt the car was running too much boost and that it was running rich. The first run confirmed this with a very jumpy power curve although the AFR was ok at a very consistent 11.4. Peak power was 196rwkw. This was at 13psi.
Boost was then lowered to 10psi to see the effect which resulted in a very substantial drop in power. Down to almost 150rwkw.
A few more runs were made and then boost was set to 12psi because I feel that 12psi is safe enough for the street and am happy to risk it. This resulted in a similar power level to the first run but much smoother with a few dips here and there. The tuner then adjusted the ignition timing a few degrees here and there and got a very nice smooth curve. There is still one dip near the top of the range but couldn't seem to get rid of it. Final result using a peak of 12psi was 197rwkw and a very smooth curve.
I am more than pleased with this result and noticed the much smoother power delivery on my way home from the tuner.
https://www.sau.com.au/forums/topic/70447-unichip-tuning-results/
3.5" exhaust? loud car?
That's an impressive rwkw figure cos those are relatively minimal mods... nice job.
I heard that the stock R34 turbo's don't like being boosted over 12psi? And that 12 is kinda the max for them?
Car is very very quiet. The intake is noisier than the exhaust.
12psi is considered by most to be the absolute max and the previous tune was done before I owned the car, and 13psi was far too high imo. However the car has been running this for almost 2 years now with no turbo problems.
  • 5 months later...
That's a before and after.
The first red line was the shit tune that was done previously and was at 14psi. Far too much for the stock turbo and was causing surging resulting in the horrible curve. This was why I got it retuned in the first place.
The blue line which is much smoother is with lower boost as I mentioned in the original post. There is still a dip at ~5000rpm which we couldn't seem to get rid of.
Thanks Bob... do you think it's worth the money? Or better to stick with actual ECUs
Do you think that dips and flat spots on the graph is due to the difference between a chip and a ECU? Maybe this is a trade off between the two?
I've got a R34GTT in tiptronic as well... currently using the SAFCII (tuned on Monday). Attached are my dyno graphs (sorry about quality). Peaked at 194.6kw which is less than yours (probably due to absence of full exhaust)... Also only running 10psi of boost
Power curve is smooth, AFR curve is quite roller-coaster-ish
Edited by satanic
Yeah I was just looking at your post.
Tempted to photoshop away the red curve to illustrate that the blue curve is much smoother but couldn't be bothered.
At the end of the day a unichip really is just a glorified SAFC that can do ignition timing. So you would expect similar results, and as dyno results read different, who knows, yours may have more power.
That's where I think your unichip will have the advantage... the timing! Unlike yours, the SAFCII is limited to AFRs but the chip can have a lot more stuff put in provided that the tuner knows what he/she is doing...
Worth a thought.
its a reasonable but that hole in the mid-top end shouldnt be there at all.
That would be quite noticeable id imagine
Hmm does anybody know how many load points or what the map setup of the Unichip is? i.e. The SAFC only has 12 points which are set via RPM, while the E-Manage has a 16x16 map of RPM vs. TPS.
None the less thats still an awesome power figure for such little mods! How come your boost isn't even though? It seems to be at around 12 or just under for abit and then drops to 10psi as you go up in RPM/Speed. What boost controller are you using?
Sorry for not reading your first post properly NJR.
Ongsta - Greddy Profec B boost controller (taken from first post also)
R31Nismoid - it's still a piggyback when it comes down to it. I think it's a good result.
NJR - does the ECU still drop the timing at gear changes at high rpm WOT? Or does it sort of slide into gear?
This thread certainly livened up!
The flat spot isn't really noticable to me, but it could be to others. We actually tried changing the timing around that load point to make it better but could not make any change to it.
As for the boost tapering off, I suspect I have a leak in my turbo-exhaust gasket which is making that worse.
I'm not sure how I'd describe the gear changes as they all feel slow to me as all my previous cars have been manual and don't really have anything to compare it to. I think though I'd lean more towards the glide into gear, the tranny had issues with the previous owner and had many parts replaced so who knows.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
