After fitting the new springs and shocks the cars feels really good one the road. I used to have problems with under steering cause to front was bouncing so much.
Just a couple of points for others to remeber when doing the same job.
1) Be prepared to spend the whole daying doing it.
2) It is an absolute pain in the a** of a job.
3) the back strut tower bolts are located under the parcel shelf and can be a huge pain to get to depending on your factory sterio option. I have factory splits in the back which had to be removed along with the seats and parcel shelf.
4) if you have a press it would be very handy for pressing on the bottom spring plates to the Bilstein shocks (I had to use the old persuader (hammer).
5) Make sure you have spring tentioners.
The rest is easy but frustrating :)
With this setup the guards are about 10mm from the tyres (with 18's) but may sag a little more. The ride seems to be nice and firm but not to firm...
Sorry if this thread seems pointless, I am still cooling of as I just finished it. I needed to vent :)
https://www.sau.com.au/forums/topic/70450-so-i-just-fitted-kings-and-bilsteins/
i put in whiteline springs and bilsteins a week ago,
it took about 45 mins to remove the coilovers..
i found it very easy (with a friend who had done it before) to put them him, the only problem was:
as you said, the bottom plate for the springs would not go on for the rear shocks. the fronts went on easy. i called whiteline they said it happens sometimes, and if there was a shart edge they sometimes need to grind it off..
There were no sharp edges, the hole was just too small!!
so we used to dremel to grind the hole out a bit more and them it all went well.
(i did try and use the 'persuader' at first :) )
all up fitting took about 4 hours including removing and refitting the interior.. the whiteline springs didnt need to be compressed to fit in..
How much did it set you back? Looking at getting some to do mine shortly.
Well I payed $1000 for the bilsteins and $320 for the kings. I got the kings from capital steering & suspension and the socks from pedders. I had to haggle a bit with pedders to get the shocks for $1000...
you can get the whiteline sports pack (springs and shocks) from UAS with sau discount.. comes to around ~1215
but can add up to more once u buy dust covers if needed (i got 4 new ones) which are not cheap, around 20-25 each
I used the low ones which are supposed to lower the car 35mm at most. You have the option of standard, low and super low. But I would not go the super lows because it would cause camber probs....
Yeah i am looking at geting the "low" springs
How does your car sit now? do you have a pic?
is the UAS discount only for NSW members? Or being a Vic member, can i apply for the discount?
how you finding the springs/shocks anyway siksII?
cheers.
Hey, im pretty sure its just for forum members too ie. just mention sau and they will see what they can do, speak to john(boss)
the springs and shocks are just what i was hoping for, car rolls less and is a lot easier to drive, ride is similar to standard ride.
only complaint is the front end feels less precise and stuck, although u do get some stabilising understeer before the tail comes out, so plenty of warning..
also when the front/rear comes out they slide nice and smooth, just overall making the car easy to drive, especially on bumpy(ALL) roads
i used to have coilovers and there is no way i could have rounded corners as quick or as stable as i do now..
Did you consider just getting new coils made for your coilovers rather than buy whole new suspension???? Much cheaper option. Obviously depends on the condition/quality of the coilovers.
hey, i considered this, but decided against it, i wanted a very good setup, and dont have the knowledge, and dont really trust suspension places to make up a set of springs to suit the shocks that would work as well as the whiteline setup
so basically i wanted a minimum of stuffing around, also my alloy tops were very noisy, so i needed to get rid of them anyway, they annoyed me!
i sold my coilovers for around $500 so in the end it only cost about 800 (1300 all up)
for springs, shocks, strut tops(from a forum member), bump stops, and new dust covers
i installed myself otherwise that would have been maybe an extra 250 or so.
  • 1 month later...
I'm on this path too, already have the Bilsteins installed, although they've been working too hard with the shit springs, so I suspect they'll need a service soon... I just rang Repco for a quote on King Springs low's, and they said $220 for front AND back springs, with $10 freight... that sounds... wrong.
Anyone confirm or deny that pricing? :P
Nah, he said $110 for each set, meaning $220 all up... but maybe its more the truth, considering you feel that $440 would be too expensive.
I gave the Repco on the other side of town a call, they said $161 for the fronts, and the rears weren't in their catalogue. :P
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
