  • Replies 53
in my experience the 2530's come on about the same as stock turbo's(3500rpm), were as cars wich have GT-RS's kick hard at 5000rpm.
What do you mean by "come on"? A stock GTR seems to make 1kg/cm boost by about 3300RPM under load. There is no way 2530s will do that.
All the ones I've seen (I'm not saying it can't get better) make 1 bar at just under 4500RPM.
Here is the dyno graph for Antz car. I took a pic of them yesterday. The dyno reads 10% and reads 360rwhp = 396rwhp taking into consideration10% loss. This works out to just under 300rwkW and Im sure if we were to run the car on a calibrated dyno that it would read 300rwkW.
that is a great result mate. 2530s on a GTR is a nice combo.
I'm not to sure on this "their dyno is low so I ad 10, divide by two, plus my age, times 11 equals the true figure" business though. to me that graph says 360hp. if their dyno is not correctly calibrated then they should get it fixed and you should probably take the car somewhere that has acurate, operating equipment. otherwise you are just speculating so what's the point of having it dyno'd for a power figure in the first place?
LOL, come in your car and race and see if its not 400rwhp. This dyno reads 10% low and has been verified over and over and if anything the dyno reads slightly lower than 10%. We don't really give two shits what it reads in the end because we're not there for the dyno, we're there for Matt Spry which is an expert tuner. If we want to see the power, we'll take it to another dyno that is accurate or hell one that reads higher than normal...then you'll believe the car makes 500rwhp with n1 and standard fuel pump just cause the dyno said so.
Speculating? Read above, we're not speculating but at the worst, misestimating by 2-3 % either way. Point of having it dyno'd for a power figure? LOL...it wasnt to get a power figure....it was to tune the car with the recent addition of N1 turbos. And anyway, it is a trialled and proven combination: N1 turbos make 300rwkW and thats not 360rwhp.
In my experience, no, they don't.  A few facts, we get 1 bar out of the 2530's at under 4,000 rpm on the RB26.  The GTRS moving parts (compressor, shaft and turbine) weigh 25% more than the 2530 moving parts.  So there is simply no way that they can be as responsive, given all else being equal.
This experience is not unique, the 2 fastest GTR's at Tsukuba again this year where both running 2530's.  If the GTRS's where as responsive and made more power, I am sure the unlimited budgets would have funded them.
Before my engined failed, I was getting the same boost almost 1,000 revs higher with GT-RS terbs, so even with "tweaking" the cam timing, it just won't be possible to get the same response out of the larger terbs as SK says.
I'm believe with the head work, cams and internals that I've had done to support high RPMs that I will be able to reap the benefits that these terbs should offer over the 2530s. Will need to wait until I get the motor rebuilt ( again ;) ) to quantify the benefits (if any).
Ant - nice work mate, great that the stock AFM's and pump managed that much!
that is the way a graph should look :wassup:
Sorry mate did not get a print out of the boost curve, all I could tell you is that we managed to get that power @ 17.75pds which sounds about right to me.
Ant...do you have a graph with a boost curve?
Sorry mate did not get print out of the boost curve, all I could tell you is that we made that power at 17.75pds. It was enough to blow the intercooler piping off as well.
No need to fuss about this, as I will do a power run on Chiptorques dyno which will give another result all together. I know that all dyno's read differently to one another but as far as I'm aware I am adamant that the power figure is closer to 300rwkw than anything else.
Antz
The power curve seems a bit "peakier" with full power a bit later in the rev range than I would have expected with 2530s.
The link below is what I achieved with what should be laggier GT-RS terbs. Note that there had been minimal setup of cam timing and boost was a moderate 17 psi or so.
http://www.skylinesaustralia.com/photopost...&cat=500&page=1
Antz
Nice going Gav, 473hp is very nice indeed. GT-RS turbs are laggier though.
Things to note, is that my turbos are not 2530s and in fact they are not even ball-bearing, hence the spool up delivery is certainly not as instant as bb turbochargers.
Even my bros. gets ahead of me in the lower rev range and he has an FJ20 (na block) with a GT30R!
Ahh.... sorry Antz, that's what happens when I don't read the thread correctly!
Hope to have some reliable mid 550rwhp after the next rebuild and with a bit of work should be able to bring on the boost a bit sooner and eliminate the terb shuffle (although it does get other driver's attention when it sounds like a train is approaching them!)
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
