I had my car tuned and dynoed late last year with a reputatable tuner in Melbourne my car made 195rwkw (mods are in sig). They said the car was making very good power for the mods the had. I was very happy with the job done and the care they took.
Couple of weeks ago I entered the dyno comp at. The car was running great but it only made 156k atrw. I told the dyno operator the power my car had previously made on another dyno. He said that there a lot of people out there who are tuning cars and giving extra high readings to the customer to keep them happy. But everyones figures seemed very low to me, stock 300zx manual 136rwkw and, EL straight six falcon with full exhaust and CAI 75rwkw where a couple of examples.
Having done my research on the forums it seems most people with these mods seem to have from 180 to 200rwkw (correct me if im wrong).
Last week later i watched a DVD called grunt files with a very interesting part about dyno's. They showed who how a dyno/car should be set up for a power run on a dyno if the operator does not pay attention to all steps the figures could be out by a long way.
After watching this I relized that guys running the dyno comp missed some very important steps.
Some of the steps from the DVD included.
1. The inlet temp sensor must be in the airbox or on pod. (not done at comp)
2. Exhaust temp sensor must be in the exhaust. (not sure if this one was done or not).
3. Humidity, temperature, and altitude must be entered on the PC.
4. Fan to represent the car on the road. (not done at comp im surprised my car didnt detonate like hell)
This DVD is worth a look for this section alone.
So people beware that if you are going to enter a dyno comp that all the necessary steps are being taken or else you will get inaccurate readings.
https://www.sau.com.au/forums/topic/70486-dynos/
136rwkw seems high for a stock 300zx manual though.
at one dyno day i went to i saw a few 300zx manuals all pull around 125-130rwkw i was scared because i thought my r33 was only good for that..
my near stock r33 pulled 165rwkw which was definetly way higher than usual on that same day.
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1302510
I'm tired of dyno figures. they suck arse. :D
I know my stock 32 went from 115rwkw to 125rwkw to 152rwkw to 164rwkw then down to 160rwkw then up to 176rwkw (with pfc & Rb30).
The 115 (stock psi), 125(stock psi), 152(12.5psi) & 164rwkw(15psi) was the same dyno.
160rwkw(15psi) and 176rwkw(9psi) was on a different dyno
I've used 3 dyno's in Adelaide, all very close together. Within 3rwkw.
Temp sensor placed correctly, tyre pressure the same etc.
That being said, A dyno is only usefull for comparing figures for your self or others that have used the same dyno & operator.
sexy-gtst.. what were your AFR's like?
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1302976
150rwkw in mine used to have it spinning up 225's through first as soon as it came on boost when rolling slowly then planting it. Slight lag then wheel spin and a bit of axle tramp on the stock soft suspension. :D
Quick change in to second could have it swinging the arse end around until road speed caught up to 7000rpm (100km/h approx).
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1303296
150rwkw in mine used to have it spinning up 225's through first as soon as it came on boost when rolling slowly then planting it. Slight lag then wheel spin and a bit of axle tramp on the stock soft suspension. :)
Thats why you should spend some cash on your tyres. Those Bob Jane - Assie all rounders are good for 200,000 km, but they have as much grip as seven layers of pig snot on a door handle. :)
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1303519
Thats why you should spend some cash on your tyres. Those Bob Jane - Assie all rounders are good for 200,000 km, but they have as much grip as seven layers of pig snot on a door handle. :D
lol.. believe it or not that around that time I was running Goodyear F1's & bridgestone donuts. Supposively they are supposed to grip well.
The RB20DET is a different motor to the RB25. The RB25DET making 178rwkw I drove was very linear. No snapping affect like the RB20DET.
The RB20DET felt as if it was able to snap sideways out of a corner easier than the RB25DET.
Recently I've been running Simex 225 50' 16's as they grip better than the bridgestone and goodyears for acceleration, the last set I got almost 40,000km's out of. :)
Their cornering ability is less than desired (very soft sidewall), not to mention wet weather. lol
This time around I think i'll try the Sumitomo SRIXON4 or a set of Toyo Tranpath SW, not too sure. I'm still googling. ;)
I want some thing that i can get decent kays out of yet have decent straight line grip.
I may step back to the sloppy jallopy Simex.
I'm not much of a corner thrasher anyway. Not on the streets anyhow. :)
Simex are decent for grip for what they are. I remember Rev210 ran his 12.9 on 205 simex tyres. lol
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1303588
It has been said before but I will say it again
A dyno is a tuning device ONLY
Dyno figures dont win drags or circuits. If they did the race would be won or lost in the workshop, and there would be no point going on the track.
sorry but a dyno is an indication of how much power u have at the wheels it is not only used for tuning!...
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1303597
A dyno will indicate the improvemanet of power for a given set of modifications, (provided you use the same dyno and they are consistent in their readings), but gives little to no indication of how the car will perform on the road.
eg - I'll take a 100rwkw bike over a 300rwkw car, but even in this example ther are so many variables that could make one a lot better than an other.
https://www.sau.com.au/forums/topic/70486-dynos/#findComment-1303807
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
