some of u might know that ive had a cooler sitting in my room for like 2 months now,so im finally putting it in, the pipeing is 1/2 done,but im kinda waiting a few more days as im waiting for a turbo, anyways heres a pic of what im doing, does any1 think this is a better idea than the usual way or what?
personally i dont think theres much difference as the japs have been doing the throttlebody pipe going the long way around the engine for ages
anyways heres some pics
http://home.iprimus.com.au/pdg/intercooler...er%20piping.jpg
http://home.iprimus.com.au/pdg/intercooler...0piping%202.jpg
http://home.iprimus.com.au/pdg/intercooler...0piping%203.jpg
https://www.sau.com.au/forums/topic/7065-ideas-on-cooler-piping/
yeah I can see a problem you have the pipes going the wrong way the pipe from the turbo goes the shortest route to the cooler
and the intake piping goes from the other side
this is boostmeister piping I think it is effective adn the runs are very short .
there are aother ways as well would you like to see them
meggala
im doing it the normal way now as the pipes where they go from the turbo and the J pipe are too close,soo ill just do it the normal way and get some exaust wrap to put it around the pipeing that sits infront of the engine this pipeing was PISS easy as i had no cutting at all and has so far cost me 90 bucks
A mate of mine has had the factory GTS-t plenum cut, and the throttle body added to the end, so that the intercooler pipes no longer need to go over the engine. It is an extremely neat job, looking like it came out of the factory. Although it would cost a bit more than than running the pipes over the engine it is a much neater and more efficient design.
Just my opinion though.
See'ya:burnout:
See'ya:burnout:
To be completely blunt, and to risk being called "arrogant", that's the worst idea EVER. :D
The stock inlet plenum has baffles and air deflectors inside the plenum chamber to distribute air flow evenly to all 6 cylinders. These baffles and deflectors are designed for a side intrustion design, and if you weld that shut and move the air entrance to one end of the plenum, you'll completely disrupt the airflow characteristics of the plenum chamber, and risk having a few cylinders run rich, and worse, a few cylinders run LEAN!
To be honest, I know a few people who have done this modification, and it *seems* to work okay, but I sure as HELL wouldn't consider doing that on my car.
Invest in a proper plenum chamber, or live with another ~80cm of piping IMHO.
I agree with you Merli, I have a Greddy plenum, but it costs $1600, and I know most people don't have that sort of money. I agree that the airflow disruption could be bad, but probably no worse than heating the air by going back over the engine like the normal GTS-t design. Don't think its the worst idea ever, the guy is making 300rwhp.
I only added it as another suggestion, not one for us with the money to do it properly. Don't worry I don't think your arrogant, I will only do it to my car if it is the best way, but that usually means expensive.
The do it properly or not at all is probably a little on the harsh side for those people without the money to spend on there cars, there are a number of techniques that can improve the power cheaply, but aren't necessarily the best way.
There are alot of people starting to make custom plenums for Skylines, I know of 3 people in Perth who's designs are excellant, it not cheap but definately cheaper than the Jap ones.
See'ya :burnout:
Not really, as there is nothing really wrong with having the piping go over the top of the radiator, like most Japanese kits.
I haven't done any testing, but I would assume intake temps would only pick up a few degrees extra heat by passing over in this fashion...
If you wanted to goto extremes and relocate the throttle body, you would be chasing extreme horsepower (if not, that money would be better spent elsewhere).. and since you are chasing extreme horsepower, you will most probably be spending big on other parts of your engine, so it would make sense to do everything properly, and not do cut and shut jobs.
GReddy plenum is $1300 from Japan, and locally made ones can be found for less than $1000. Still a lot of money, yes, but as I said before, when chasing extreme horsepower, $1000-$1300 isn't a lot in the big scheme of things...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
