You get to talk to all sorts of strange people when seaching for a car the best one I heard today was from a kid that sounded like he was 18 yrs old (sorry this is not meant to offend our readers) anyway with my enquiry into his R33 which sounds like it is stock with no mods on it at all he claimed that the car which he has never taken to the motorplex and has never raced can do a low 13 or even a mid 12 second pass so I thought I would ask more power questions to our obviously intellegent friend, I asked how much power has it at the wheels he guesstimated about 300hp at the wheels, on further enquiries I find that the car is running only 5psi (I am a novice here but I thought that they come from the factory with 7psi) it has no filter no I/C....
Is it because I am a female that they think I am stupid.... or too embarrassed to admit that they don' know - just be nice if people could be honest - I understand honest - nearly everyone I spoke to all people who had cars for sale had never raced there cars and I was enquiring into some fairly modified cars
https://www.sau.com.au/forums/topic/70810-strange-people/
ROFL, stock 5psi and running 12second ahahah that is classic
i might be becuase your female, and they think you no nothing but most likly its cuz they know nothing and watch too much TFATF, i know a few people with import cars that think the only differences between a gtr and a gtst is the rb26 :rofl:
keep looking, im sure you will find something :)
https://www.sau.com.au/forums/topic/70810-strange-people/#findComment-1306018
i loved it when i asked a friend why their POD was packed with carpet off cuts whats it meant to do? he told me i was silly and it was to help his NOS flow better because there were bigger gaps in the carpet pieces....
i couldnt help but wonder if he was serious?
https://www.sau.com.au/forums/topic/70810-strange-people/#findComment-1306432
well I have not found too much which is a surprise as a few of my friends have said to get a different kind of car as there are too many skylines around and they are common now - not sure if there could ever be enough skylines around to make them as common as a commodore or falcon.... there have been maybe 2 cars that have caught my attention but if I had to really narrow it down I would have to say that Steve's car sounds very interesting, I am however looking at 2 cars on friday both are 1995 and have done similar klms but 1 is auto which the dealer says that it is very quick for an auto ( I do trust this guy we have bought cars from him before ) and the other is a manual which was once a auto ? both are a grade 4
so will take both for a drive and see what is what
I phoned the gentleman in Rockingham and the car is sold :P
I don't care really if they have raced the car because the motors in these cars are very tough and are almost a detuned version of what they could be... but again it depends on the mods that have been done a stock skyline that has been raced is a fairly good car to buy but a fully worked beasty that is running 18psi all day is going to give me a small hesitation
https://www.sau.com.au/forums/topic/70810-strange-people/#findComment-1307987
The rb25 has a solenoid as standard. before a certain amount of rpm (~4500rpm) the boost is kept to 5psi and after 4500 rpm it goes to 7psi. if u have a bleed valve installed (and fully closed off) you will bypass the solenoid therefore keeping the boost at 5psi. i also thought the wastegate spring was a 7psi spring but its not. im pretty sure its a 5psi spring, the solenoid bleeds off some air after ~4500rpm to reach 7psi. i thought there was something wrong with my car when it was only running at 5psi then i found out what the story was. if u dont believe me do a search....
https://www.sau.com.au/forums/topic/70810-strange-people/#findComment-1313561
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
