Hi!
Just got my 1st Skyline yesterday. Just want to ask some basic questions?
1. How do I make the dash lights brighter? is there a knob somewhere?
2. My horn doesnt seem to work, how do I rewire it?
3. The off button near the A/C doesnt want to work. How can I turn off the fan that is turned on for power 1?
4. Whats the best way to clean the car? Buff it? or what cleaning solution/wash powder?
Thanks Guys!
1. There should be a non-descript knob somewhere, it's usually a dick smith looking thing and it could be anywhere because it's put in for compliance and not factory.
2. Take off your steering wheel and re-connect it. Should be pretty obvious (1 positive wire, touch it (ie. ground it) to the steering wheel and it should go beep. If it's fallen off you should just be able to re-connect. If it won't beep when you're grounding it and it's the right wire then you might wanna test the actual horn.
3. I think that's climate control so to turn it off try hitting manual? Then the fan (if there is one I don't know about r33 sorry).
4. If you look in the tutorial section of this thread there's an excellent how-to for washing and buffing and polishing your baby.
Take care.
If the off button is broken you cant stop the fan, as long as the other buttons work ok you can still use it in auto or manual modes. You will still be able to switch on & off the a/c, fan speed, vent control, heat/cooling and manual/auto modes. Mine broke a couple of months ago annoying at first but aslong as all the rest of it still functions right you can get used to it.
The only way to stop the fan is with the off button. You can turn the air conditioning off and moderate the temperature and fan speed (1, 2, 3 or 4) but there is no 0 speed for the fan.
I'm not sure if the fan resets to off when you turn the car off and my 33's at the shop atm so I can't test it but this might be the only way. If it doesn't reset, then you're going to have to deal with it or get and auto electrician to have a poke. An alternative would be to rig up your own switch to the fan which just cuts it power (tap into the earth wire). You could get a mechanic to do this for you if you don't want to try it yourself.
Glad you like the car, when you get the chance drive it over and we can tinker with it. I have a spare Streering wheel to try on it.
Does the relays in the engine bay click when you push the button?
That sounds even more backwards than the test we have for cars 10 years or newer called the ESVA, right fools down at the testing stations, you know the type, got bullied at school so takes it out on every one else now... Very annoying people!
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
