hello all.
i am about to import a R32 GTR with a R33 GTR N1 spec engine in it. Now, from what i've seen, the import sheet says the engine is 400 ps claimed. Now this works about to be about 295 kw's according to a converter i have found. Anyone know for sure??
Anways, i need some1 to tell me what the difference between an N1 engine is to a standard one? I've searched google but am struggling to find any specs. Links would be good if anyone has found any.
Cheers in advance guys,
Regards,
Shaun
is this the car that was listed for sale in the for sale section ?
Hi,
i've checked the first four pages of the for sale section and it's none of the GTR's listed, the one i'm getting is white. Also, this car is still in Japan.
Do a search on this site, quite a few differences main one being stronger bottom end.
Hi,
I've searched the site a number of times typing different keywords, and all i've got is threads which mention N1 turbos, parts, etc etc, but not engine specs. If you have links to direct threads, that'll be a great help.
Regards,
Shaun
hmm ok the thread must have been deleted because a guy had it up for sale and then others were asking if it was the same one that was offered on the jspec website. or something :P
and it was white.
anyhow ... sounds like a fun car !! :D
also...
yeah 400ps is probably around about 400kw which is also around about 300-odd horsepower.
and the N1 engines i think have oil cooler from factory, also slightly bigger turbos than standard. not sure bout the internals though.
400ps is 394hp which is 294kw...
What I know of the N1 engine is stronger engine block (extra webbing), stronger pistons, steel wheel turbos instead of ceramic, higher pressure oil pump, and modified water pump so it doesnt caveat at continuous high rpm (which in turn doesnt make it so crash hot for standard daily driving so ive heard).
and it was white.
hmm, that sounds interesting... mainly because i am purchasing this car from J-Spec... so it must be the same one then. Is there a way to view deleted threads or something? I'm a bit curious now, especially since J-Spec were unable to get in contact with the seller to see if it was still available **confused**
Regards,
Shaun
Regards,
Shaun
Try PM'ing "Blitz"
He is the moderator of the For Sale section and he actually posted in that thread.
:P
Thanks for the reply amaru. Sounds like a pretty solid engine... but gtr engines are pretty solid in the first place :P
Try PM'ing "Blitz"
:P
hmm, i've just tried pming Blitz but his inbox is full and he has to clear some in order to recieve my pm! :goddam:
anything else i can do?
LH side of the block, under the turbos, is a number cast into the block about 1/2 way down which reads 05U. That is a std block, N1 should read 24U
Cheers
Ken
ta man, it will be the first thing i look for when/if i get it.
Regards,
Shaun
Guest Mashrock
ohh i have n1 engine in my gtr i beleive. i should check up on this. the auction sheet wasn't too clear as to what was changed.
but i had a reported 580ps.. or there abouts.
n1 turbos can support up to 300-350kw?? true someone??
so i guess if you have the right gear you can probably make near 400kw at wheels.
Try PM'ing "Blitz"
:spank:
Holla, yep i removed that thread as it was getting nasty, it turns out the thread starter actually posted photos of the wrong car, so naturally people wondered why he was advertising a car that J-Spec still had listed as $18k and available, for $35k.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
