  • Replies 54
There are guys in South Africa that are paid by tracker sompanies to test the systems by stealing the cars.
Anyway if you know people who work in the companies that fit the systems they all know how to disarm them and where the beacons are installed.
A guy had the first SL600 (old shape) in SOuth Africa. Fitted with tracker and 2 responders running individually and the car was still stolen within a week, never to be seen again. Apparently an inside job cause the responders where fitted in totally dif places to usual.
well, the way the gps thing work is by using a phone sim card, which therefore uses the the mobile network.
the lsat time iwas at the aitport my mobile worked fine.
and when i get my trackong device, im gonna do the install my self, and it wont be a shoky job either,
steve
If it's using a a cell network then it's totally diff to what I'm talking about.
One question with that is what happens when it goes out of sim range. When I'm at my GF house I don't get any reception how would this affect that type of tracker?
The systems you are talking about are old tech . The latest trackers use GPS to track the car and gsm is only to call you .
GPS works anywhere on this earth , unless underground .
If your car gets broken in or moved from where you last left it this is what the tracker will do . If it has gsm reception it will call you instantly and tell you what happen to your car ( like intuder detection ) will tell you if car is moving , what derection , speed and location , its that accurate you can tell which side of the road the car is . Then you have option to cut the engine and if you have the software you can see on your p.c. the actual road its traveling and the speed at one sec intervals . I know someone that got out of a speed ticket when he produced the log to prove he was not speeding !!! This system is much more accurate than the police radars .
If there is no gsm reception when they brake in then it will call you as soon as it gets reception , in Sydney for instance that will be very soon .
Now lets say they take the car underground you will loose track of it but it will tell you the last known location and as soon as it becomes visible again you track it .
Now you tell me a better system and i will install it in my car now .
I have other options ( i wont go in to them here for obvious reasons ) in my car and i can guarantee that if i gave my car to an expert for 8 hours they will not be able to start it .
The reason i have the tracker is they may tow it or carjack me , if they car jack i'll give them the keys and as soon as they go i'll cut the engine on them with any phone .
If they tow it away then i can see where they are most of the time , they cant stay underground can they ? If they park it in undergroung carpark i'll know the driveway they used to go under then i can find it .
This system allows you to moniter the speed as well , say you lent your car to someone , then you set speed warning as soon as the car reaches that speed you get a phone call .
In the years to came every car will have one fitted in it , as they become cheaper .
Mate what security system are u talking about, i'm interested in getting something like that for my R33.
Its called ezitrak , go to www.rojone.com and read all about it .
Threre is a group buy going on on these forums .
A number of forum members have the system in their cars .
First they have to know that you have such a thing in your car and they have to subpoena the log by that time its all gone it only stores a couple of hours on the log .
So no it wont work that way , you only use it when it suits you .
Are we talking an active and remotely logged system? I think some people are worried as to where the data is stored as to being accessable at some stage in time.
BTW Tikki some interesting forms of car theft defence in SA, I've a friend who was there and hes had some great stories to tell !
the data is stored in the actual unit, and only a certain amount of time is stored, so old data is pushed out as new data is pushed in.
it is only accessible by using a password after dialing in from a modem.
Yip there are some really weird and wonderful ones. One guy developed a system that worked witth the anti hi jack. If it wasn't disarmed after 2 min the doors would lock, power windows would wind up and lock then the car would cat and power off..... then drop a canister of tear gas into the car. It was never allowed because it could and more than likely would kill you from suffercation.
There is one guy that has a spring loaded razor sharp bar mounted on each side of the car. If someone tries to hijack him it can be released and is powerful enough to chop a leg off. This isn't legal as such but the guy has never been successfully prosecuted for it. And then there is the yeee old flame thrower kit. Jets mounted at each door so if anyone tries to climb in you just press the button and roast hi jacker. There are loads more but mostly people have just taken to arming themselves cause a Hi Jacker feels f all for killing you to take your car. I've had a friend killed and a friends father killed over a hi jacking and they didn't end up taking the car.
I seen a picture awhile ago of a lock that clipped around the gearbox shifter, I assume so people cant change gears if they try stealing it by actually driving it away.
Does anyone know if they are any good and where I could source one from?
I know the device that youre talking about as one of my old friends had one. I think it was piece of metal attached to the seat rail and a u-shaped piece of metal that locks the car into 5th gear. Sorry no idea where you can get one.
Good idea, but I think thieves would of broken the window sat down in the seat before they realized it was there. Might keep the less experienced thieves out but would still be out of money for the break in.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
