Guest Boxhead
depending on what mesh your looking for.. obviously if your looking for that ricey mesh stuff i think auto barn gets it.. you can spray it black, but with my old car i needed to find a bigger peice to fit fmic part(i know i dont have one, but the hole there) so i was looking around, and auto barn arent that exspensive, its just in general not cheap..
if you just want some basic black stuff to protect intercooler etc, then NIZ30 said he asked a plumber or somethin for some, paid $5 for enough to do his bar twice over(from what he said)...
https://www.sau.com.au/forums/topic/7100-wire-meshing/#findComment-104781
Originally posted by franks
im sure a place like jetspeed or carmate would have mesh. though carmate's isnt the best. its like chicken wire...i removed all of my mesh from carmate - i'll be visiting jetspeed soon i think...
hahahahah and u rekcon Jetspeed is gonna do a better job!??
Frank trust me , just get some mesh and do it your self, don't give it to jetf**k i mean jetspeed, :D
i can't stress that enough
Donnie
https://www.sau.com.au/forums/topic/7100-wire-meshing/#findComment-105136
i was reading on *cough* ford forums that theres this place called Metal Mesh up in Terrey Hills that has alllllll sorts of mesh, even some nice stainless steel stuff in different sizes and gauges at very very reasonable prices.
i think its www.metalmesh.com.au
check it out
i gotta head up there for some nice stainless stuff soon
https://www.sau.com.au/forums/topic/7100-wire-meshing/#findComment-105166
Guest Boxhead
check it out
umm so far they do look like they make good stuff, but me and dave called them, for stuff like what auto barn has..
you get it in like a sheet of 2 m by 1m,
and it costs $115 i think.. well its over $100
so it might be wise to split it with someone :S
https://www.sau.com.au/forums/topic/7100-wire-meshing/#findComment-105231
i got mine from a place at smithfield area the places name is
ULRICH aluminium (i think thats right).
they had a couple of different types to chose from including the most popular/common types
i got a full shet (2mx1m) for mine for only $50 easily enough to do the front bar on 2 cars. mine is a 400R bar so i used quit a bit but still had heaps left over.
best way to fit it is to take your bumper off measure the size of each individual piece of mesh,(from the inside of your bumper) with enough excess mesh to fold over the corners and sides of the holes your putting the mesh in. once in place with the side folded over use hot glue to secure it, easy as that.
the hot glue is very god for this cause you dont need to drill ugly holes in your bumper.
mine turned out great.
https://www.sau.com.au/forums/topic/7100-wire-meshing/#findComment-105276
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
