I personally think that people at regency are not as bad as you guys say..
I've been there b4 with my previous car Mitsubishi FTO. I waited there for a short while and chatted with a few inspectors and workers there. They were very friendly and even commented that i got a nice car! They even directed me to where i needed to go...very helpful....will recommend....
  • Replies 48
yeah, there are like 20 of us all making up Regency horror stories for the fun of it .... some have reasonably good experiences, but most don't.
When I had my 1992 MX6 (non-turbo Aus delivered) and moved from Darwin to Adelaide, I went in simply to get the vin checked and copped a heap of warnings and near defects while I was there - including being given a razor blade and made to remove my tint before I left, as although it was legal, it didn't have a % tint sticker on the window.
Mate you are kidding arnt you?? Regency have the power to defect cars, why when you take a car there for a full inspection 9 times outta 10 does it come out with a yellow sticker on it??? (or more yellow stickers if you've already been defected) Regency is like the head judge mate, they interprete the laws as they see it.....Don't kid yourself :Bang:[/
i did know that when you go to regency already defected they have the right to defect you for further things and put another canary on your window, but i didnt realise they could give the initial defect, sorry for being so naive :Oops:
Mate you are kidding arnt you?? Regency have the power to defect cars' date=' why when you take a car there for a full inspection 9 times outta 10 does it come out with a yellow sticker on it??? (or more yellow stickers if you've already been defected) Regency is like the head judge mate, they interprete the laws as they see it.....Don't kid yourself :Bang:[/
i did know that when you go to regency already defected they have the right to defect you for further things and put another canary on your window, but i didnt realise they could give the initial defect, sorry for being so naive :Oops:[/quote']
Sorry post might've been a bit harsh, but yersh long and short of it is that regency are head judge, they can AND do what they please...
i got the same letter aswell nearly the day after i had lowered it and put some rims on, but as far as i know regency dont have the legal right to defect a car they are a seperate entity to the police, inless the police are waiting for you there i dont think you would have anything to worry about.
Road Traffic Act
http://www.parliament.sa.gov.au/Catalog/le...s/r/1961.50.htm
Road Traffic (Vehicle Standards) Rules
http://www.parliament.sa.gov.au/Catalog/le.../r/1999.235.htm
Road Traffic (Miscellaneous) Regulations
http://www.parliament.sa.gov.au/Catalog/le...1999.236.un.htm
About the only legislative stuff I've studied in detail... The stuff I'm meant to do for uni bores me lol
I havent had to go in and get the plates fitted to my DR and I first registered it and recieved the letter over a year ago
  • 3 weeks later...
The guys down there don't know what they are doing!  Wonder if we'll get a letter at a later date too?
Geez they don't waste any time sending those letters out do they?!
Only got the car through Regency and registered last week and got the letter in the post yesterday.
mine took about a month after rego. my boss believes he got the same letter with one of his imports aprox four years ago and thus he believes its bogus, SA will never get around to it.
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
