Ok, what I would think to be a really odd sort of problem.
Good old RB20DET gearbox, its got brand new bearings in it, and when all that happened the sincs were also deglazed, and in general I was given a gold medal for my gearbox (selector broke, hence the semi rebuild, much cheaper to do both at once). So going by that its is NOT sincs.
Anyway, the problem is the gearbox is horbile until the car is warm (ie, 30mins or so of driving) and the gears mostly 2nd & 3rd crunch rather badly, more so 2nd on down shifts. (3000rpm, will not go in to 2nd at all). You can all so feel it being a bit notchy on the other gears.
Then once it is warm, it will do whatever I like fairly easy. Still isnt too keen tho until about 1-1.5hours of driving.
So, today the gearbox oil was changed, this makes the changes smoother once its warm, and the whole feel of the box better, but didnt do bugger all to stop this crunching.
So my question is, what the hell could it be!?
https://www.sau.com.au/forums/topic/71101-rb20-box-cold-bad-warm-d/
We put in some fancy pants motul stuff.
I dont see how it is "tired" tho when its been basically rebuilt other than the syncros as they were in tip top shape.
My point is after 1hours driving or so, not even giving it any, just sitting at say 60-80kmh its 100% fine, no crunch or anything. This is what made us think it was the oil, as its still crunching even after fancy pants oil, its got to be something else, just using logic and process of elimination.
But with a semi-rebuilt gearbox that daveo described he should be able to put in servo gearbox oil and still be ok.
Daveo is it possible something wasn't installed back in correctly ie. bearings in clutch, mis aligned clutch plate etc? I guess this wouldn't make sense that it's ok once warm.
Just out of interest how much did you pay?
It was $900 all up including labour to take and put the box back in, and also the 5th gear selector fork. But as they had to pull the box apart anyway for the selector it would be approx the same.
But anyway, back on to the topic in hand. We igorne its the bloody oil ok. As WHEN IT IS WARMED UP IT IS OK!!! The gearbox is smooth other than that crunch. After thinking about it a bit more today i noticed its almost like a switch, it does it, then gets to a point and goes away. It doesnt creep up getting better. (or so I think, it could be me just hear CRUCNH, then I shift like a full on pansy for the next 30mins)
im thinking it wasnt rebuilt right either if you say everything is new.
either that, ot the new parts in the worn box... ie shafts and stuff would be worn somewhat... it just needs to warm up that little bit.
one way around it i found, was to revmatch it on a change. Rather that just changing willy nilly till its warm. Worked for a while for mine till it got really sck
Still crunches rev matching, as I almost always do that anyway.
I had a thought today that maybe its the clutch over extending, and when it warms up the clutch line expands more therefore canceling out the over extention? Im going to get it back in next week try and get an idea on what the hell is going on with it.
Just a quick bump with for this with some new info.
mechanic has had a bit of a play and a drive, and he seems to think it would probably be the gearbox. And more specifically the 2nd gear syncro being too tight.
Now my question is how/why does this happen??? Such as would the rebuild have caused this, or is it just something that can happen.
2nd question, is there a 'band aid' fix for this problem? Such as thinner oil, some kind of additive etc? Or even something so the box just warms up quicker to lessen the time I cant get it in to gear.
Serious suggestion this time...about 2 years ago i thought my gearbox was dead as it was having trouble shifting into gear. Turned out it was a broken gearbox mount that was causing me drama when shifting...since your box has been freshened, it could be one of those silly obvious things that hasnt been checked:)
Hmm yeah, could be... but would that really be effected by heat?
I mean thats what gets me, and should be a big giveaway to someone, once it heats up it is smooth as, shifts fast and fine, with NO crunches.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
