Well i'm guessing a lot of people would have seen the short segment on channel 10 last night in regards to the Drift Nationals rd 1 at Calder, it was pretty flamin good to see the coverage :headspin:
So if anyone wants to contact 10 and let them know what they thought, either give them a ring -
Here are the local numbers for around Australia:
Qld: (07) 3214 1010
NSW: (02) 9650 1010
VIC: (03) 9275 1010
SA: (08) 8239 1010
WA: (08) 9345 1010
or get onto this forum and have a say -
Don't just read the posts, register and get in there and support drift!
http://www.rpmlive.tv/pitboard/forums/9/ShowForum.aspx
Cheers!
https://www.sau.com.au/forums/topic/71155-drifting-and-channel-ten/
what time waas this on - i missed it
was on the 5pm news and on sports tonight at around 11 (not real sure of the time).
i think it might have been vic only, but they are doing a 20min segment on "Trackside" this sunday, 1pm
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
