  • Replies 412
You can usually pick the corners in the nasho by looking at them as you approach and keeping an eye on the speed signs, careful of the low speed corners tho the 35s and 45s because they vary a lot, one 45 corner might be alright, the next might be worse than some that are marked 35.
Keep an eye out for cares coming the other way too, that and wild life is probably the most sketchy part.
Just got home, helps when you only live 10mins away from tthe nasho park turnoff. Great cruise, must have been about 40 cars there. All went well despite some early attention from from the cops at Kirrawee, apparently they ran my number plate through their computer but as car business registered they got zip. I was in the pearl white 4 door R33. My first cruise with you guys but definitely not the last. When's the next one??
yeh that was my first cruise with the boys/girls..
had a good time apart from nearly taking out the railing on the last bend....
meet afew of the people on here aswell...i'll see you all on the next cruise!
Guys post of some of those photos that were taken, especially the big group photo at kirawee!
Had fun as well pity noone could understand the meaning of NOT EVERY1 IS READY!
Me and dan and some others were left behind because of some hasty retreating . Solo run for us was fun.
Meet up point was a nice lookout but thats about it.
Good too meet some new faces, Big HELLO to Daniel and Jerry and the rest of the crew that i spoke to .
Finnaly made it home in ONE piece!
P.S That R32 GTR was having a bad day i think cause he nearly killd himself , Bloody HooNs :)
the night was good, for once my bleed valve decided to give me full boost(only 10psi anyway) also cold air so the car was going great, lots of people too always good! i hope to see some pictures from the people who took them soon..
good news, no clouds and the roads are sweet! see u guys soon! :D
where the hell were you1!! we were trying to figure out who you were!!! we obviously didn't!! :) did you even turn up1?!?!?! :)
hey all!!! nice to meet some of you!!! the roads were awesome!!! all dry!!! not even any oil to make it slippery!!! the most there was, were two wet spots that i saw and that was it!!! bonus! ;)
It was good to see the cruise went through mainly uneventfully, and that everyone got home in one piece!! the only downside, was danny in the white gtr.. he got a SPANNER!!!!!!!!!!! yes i spanner, embedded into his tyre! : not sure how that happened, but luckily that was it!! after waiting for an hour and a half for NRMA, he arrived to tell us we'd be better of getting a tow truck!!! we bailed at that stage!!!! hope you got home ok dan, and that it wasn't toooo $$$$$ :(
seeya next time peeps!
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
