  • Replies 99
Won't be a f#cked cluth more much longer. Dropped my car at autoclutch this afternoon, I'll be on the road again tomorow, look out!!
The guy that picked it up said I should notice quite a diference in performance, cause the old one would have been slipping slightly all the time without me realizing.
Looking forward to the cruise. :D
Originally posted by giz01
hey are the skyline's heavier than a s14 200sx? it's just that my gf's car made a huge 126kw/170hp@tyres yet ran a 13.75! wats the story people?
Thats an understatement dude.
Allthough im not sure of the 200sx's kurb weight im guessing its about 200kgs lighter going by the s13s stats,
R33 are about 1370
R32 are about 1280 not sure on that one
The S13, S14, S15 models all seem to launch very good on small tyres too!
Originally posted by Hicks
I've never felt it grip so hard.
Im happy:D
That's a bit personal hey :P
hahah, kew dude.. good to hear... hopefully improve on that 13.7 time huh ?
i actually think your stocker clutch did pretty well considering the power/times you were putting down at the plex hey :)
Great news Hicks, a new clutch is just what the doctor ordered. Do you find it heavy under foot or not? I hope your going to the Plex this Wednesday, so you can show me what a 13.7 looks like, and then I'll try and follow in your footsteps.
The 13.9 was OK, but I want more.
See'ya:burnout:
R33 are about 1370
The S14 is about 1250 from memory. I remember the S15 being about 10kg lighter, add to it the extra gear ratio and it certainly takes off quicker.
Legal Shmegal,
Macka I say it counts, for two reasons:
1. We ain't talking about whether you won the race or not, just the times.
and 2. Jumping the start doesn't make any difference to your ET as we all know.
So. I say the 12.9 counts.....
(dude you can give me the $50 later):P
Brett
Originally posted by macka
Cheers Brett that made me feel better......
I didnt even break the start, the Torry did and i got a .221 reaction time!
I like EVL R33 but i dont skyzerr33 anymore so :P
i'm so crushed :whip: :D
ow and breaking does reduce your ET
Hey Macka, I'll be your friend for $50, I'll even say that the time was legal.:P
On the night I told you that the ET should be correct even if it was considered an illegal run, I suppose Skyzerr has to have some rules for the drag ladder.
Just can't wait till you get the car fixed and get it back on the track, give it a couple months and I may be able to catch you.
See'ya:burnout:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
