r32 GTR just arrived! Another one for perth and YES its another gunmetal grey one.
I've been giving it a good look over since it arrived and looks in good condition all round, even got all the service history! (last service 2000kms ago). Wharfies knicked my gear knob but thats all :)
Ill get some pics up soon if you guys are interested in seeing it?
Something i noticed today is that its got 255 Tyres on the rims. They look massive even for a GTR, Can someone tell me if Its this stock size?
https://www.sau.com.au/forums/topic/71503-new-gtr-in-perth/
Congrats on the new machine - hope it sees more road time than my R ;)
Std tyre size is 225/50 R16 btw
https://www.sau.com.au/forums/topic/71503-new-gtr-in-perth/#findComment-1319038
Im doing what i can to compliance it myself even as far as side instrusion bars.
But its all Cash flow.. Yours will probably see the road before mine does.
This weekend plans are to pull out the side mirrors this and get some replacements cut (flat ones). Do you want me to get some cut for ya as well? And anyone Else for that matter?
https://www.sau.com.au/forums/topic/71503-new-gtr-in-perth/#findComment-1322955
I was going to borrow some for compliance...but would'nt mind some anyway, incase that dosnt work out ;)
Let me know how much ;)
I'll be doing most of the compliance stuff myself also...so look out as i'll be picking your brain in the near future :D :D
https://www.sau.com.au/forums/topic/71503-new-gtr-in-perth/#findComment-1324121
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
