Originally posted by ONARUN
yeah it is. 2 sizes above stock is illegal and needs eng cert. 1 size up is acceptable
No its not. Its only defectable if the wheel and tyre combination varies from factory by more than 15mm.
The reason behind the width bit is mainly the change in loading on wheel bearings.
You can find a heap of shit on the RTA Website - Here's just a snippet of the information you might want to look at .......
List of ADR's can be found in this PDF HERE
List of Engineering Signatories can be found in this PDF HERE
List of Guidelines for Light Vehicle Modifications can be found in this PDF HERE
List of Guidelines for Alternative Wheels and Tyres can be found in this PDF HERE
List of Guidlines for Windscreens and Window Tinting can be found in this PDF HERE
and finally just for those who want cool Windscreen Washer Lights a list of Guidlines for Flashing Lights and Sirens
Originally posted by Strich9ine
can ANYONE point me in the direction of the ADR's So i can print them out and hand them to a pig next time I see them!???
You need to send about $23 to the Federal DOT (www.dotrs.gov.au/land/vehiclestandards/adr/subscriptions.htm ), and they will send you a CD-ROM of the ADRs.
Guest DAZSPC
Do that, and have an attitude whilst you do it and the cop WILL hand your ass a defect notice regardless.
You might be able to talk your way out of it if you do it very tactfully, but if the cop suspects for a second you are trying to make him look like a dumbass, he'll stitch you up. I'm not a cop, but thats what I'd do if you gave me attitude, so it figures that they would too.
When i was 19 driving a worked 351 clevo powered 2Door Falcon, I get pulled all the time (of course), and I got sent to the pits too often becuase I was 19 and did not know how to shut my mouth.
"OK sir, I think those headers are illegal, as is that carb, and your wheeels are definitely too large"
"As if mate, what would you know, I read up on this stuff and it's all legal"
"Oh really"
"yeah really, so why don't you go bust some real crims huh, and stop picking on us guys with hotted up cars all the time"
"OK, but before I go bust some real crims, here's a defect notice that instructs you to present your car for full mechanical inspection"
*under breath* "Shit!"
Me at 27 pulled over in a turbocharged 351 Clevo powered 78 falcon that apart from stock body and wheels, was pretty much street/drag sleeper.
cop instructs me to pop the hood
"whats all that extra piping in there?"
"To be honest officer, I don't know, I'm a computer nerd, I actually know bugger all about cars. All i know is it has that LPG feul thing as well as normal feul. Saves you heaps that does mate. Do your cop cars have that too? It's save you guys heaps, driving around all the time like you do"
"OK no worries, just take it easy next time alright?"
"sure thing"
Although it was next to impossible to "take it easy" in a car that made close to 400RWHP, I think you can see the moral of the story.
Disclaimer: The turbo'd V8 project was undertaken, when turbo's where still mainly used by heavy machinery and trucks. You could buy an EXA Turbo, and Godzilla had eaten up bathurst, but your average man on the street had no clue what a turbo was, not like now, so I prolly ould not get away with that these days.
Once and for all.....even though i can't find the rule indicating anything about 1inch over they WILL defect you for having more than 1 INCH over! So for the last time all us gtst WILL get defected for 18's. I know because i have, even though my wheel and tyre combination wasn't 15mm over.
1inch taller, and 1inch wider.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
