Originally posted by ONARUN
yeah it is. 2 sizes above stock is illegal and needs eng cert. 1 size up is acceptable
No its not. Its only defectable if the wheel and tyre combination varies from factory by more than 15mm.
The reason behind the width bit is mainly the change in loading on wheel bearings.
You can find a heap of shit on the RTA Website - Here's just a snippet of the information you might want to look at .......
List of ADR's can be found in this PDF HERE
List of Engineering Signatories can be found in this PDF HERE
List of Guidelines for Light Vehicle Modifications can be found in this PDF HERE
List of Guidelines for Alternative Wheels and Tyres can be found in this PDF HERE
List of Guidlines for Windscreens and Window Tinting can be found in this PDF HERE
and finally just for those who want cool Windscreen Washer Lights a list of Guidlines for Flashing Lights and Sirens
Originally posted by Strich9ine
can ANYONE point me in the direction of the ADR's So i can print them out and hand them to a pig next time I see them!???
You need to send about $23 to the Federal DOT (www.dotrs.gov.au/land/vehiclestandards/adr/subscriptions.htm ), and they will send you a CD-ROM of the ADRs.
Guest DAZSPC
Do that, and have an attitude whilst you do it and the cop WILL hand your ass a defect notice regardless.
You might be able to talk your way out of it if you do it very tactfully, but if the cop suspects for a second you are trying to make him look like a dumbass, he'll stitch you up. I'm not a cop, but thats what I'd do if you gave me attitude, so it figures that they would too.
When i was 19 driving a worked 351 clevo powered 2Door Falcon, I get pulled all the time (of course), and I got sent to the pits too often becuase I was 19 and did not know how to shut my mouth.
"OK sir, I think those headers are illegal, as is that carb, and your wheeels are definitely too large"
"As if mate, what would you know, I read up on this stuff and it's all legal"
"Oh really"
"yeah really, so why don't you go bust some real crims huh, and stop picking on us guys with hotted up cars all the time"
"OK, but before I go bust some real crims, here's a defect notice that instructs you to present your car for full mechanical inspection"
*under breath* "Shit!"
Me at 27 pulled over in a turbocharged 351 Clevo powered 78 falcon that apart from stock body and wheels, was pretty much street/drag sleeper.
cop instructs me to pop the hood
"whats all that extra piping in there?"
"To be honest officer, I don't know, I'm a computer nerd, I actually know bugger all about cars. All i know is it has that LPG feul thing as well as normal feul. Saves you heaps that does mate. Do your cop cars have that too? It's save you guys heaps, driving around all the time like you do"
"OK no worries, just take it easy next time alright?"
"sure thing"
Although it was next to impossible to "take it easy" in a car that made close to 400RWHP, I think you can see the moral of the story.
Disclaimer: The turbo'd V8 project was undertaken, when turbo's where still mainly used by heavy machinery and trucks. You could buy an EXA Turbo, and Godzilla had eaten up bathurst, but your average man on the street had no clue what a turbo was, not like now, so I prolly ould not get away with that these days.
Once and for all.....even though i can't find the rule indicating anything about 1inch over they WILL defect you for having more than 1 INCH over! So for the last time all us gtst WILL get defected for 18's. I know because i have, even though my wheel and tyre combination wasn't 15mm over.
1inch taller, and 1inch wider.
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
