I have read hundreds of threads about whether an rb25 turbo on an rb20 is a good upgrade or not.
I have an r32 and it seems relatively responsive, still on stock boost, but the midrange seems shit and just revs out with no real power. I need to get it tuned and i have a 3" front and dump pipe and hi flow cat to join onto my old 3" cat back system.
The other thing i read was that if you put on an rb25 turbo they get very fuelly, so i was wondering if you got it tuned after if it would fix this problem.
basically i want a daily that i can put my foot down on the odd occasion and feel it kick me back in my chair and beat commodore assholes ha ha!
any help would be good cheers
https://www.sau.com.au/forums/topic/71750-rb25turbo-on-rb20-q/
  • Replies 54
Posted Images
I am not sure I understand the question, but I will have a go......
The RB25DET turbo produces 10% more airlfow at 7 psi, than the RB20DET turbo does at 10 psi. So if you bolt on an RB25DET turbo and use the RB25DET wastegate actuator you will get 7 psi and about 10% more power. However if you use the RB20DET wastegate actuator on the RB25DET turbo it will produce 10 psi and you will get 25% more power.
That is provided you have the support parts (intercooler and exhaust) in place to handle the increased airflow.
If you really want to get the best from the increased airflow you really need to tune it. R32GTST's have an easily chipable ECU. Either that or an SAFC (or equivalent) will do a reasonable job of removing the exccessive richness that the standard ECU provides whenever the airflow is increased over standard. There is another 15% more power to be had from simple tuning.
That's more than enough to give a 255kw Commondoor a thorough thrashing.
Hope that answered your question:cheers:
Hmmm, very impressive Ronin. We have same mods but the cam gears.
How much difference do they make on a RB20. Did you do a before and after power run?
You are running a bit lean there, the power must of came down a bit once the fuel pump was changed. I had 137 rwkw but was running flat 14 AFR and after the fuel pump change it went down to 130 but very rich. The car was still pretty stock then. :D
fark ...
my r32 with stock turbo only pulled 135.5 rwkw on standard boost .. with the only mods ..
hks filter,
hks full exhaust,
standard copper ngk plugs (non iridium)
............ now that i got the fmic and new bov ...will i get more power increase??
also i have the r33 stock turbs as well but not fitted yet and i dont know if this is worth the hassle of doing without causing strain on the engine ..???
also could i boost more if i used the r33 turbo but using the r32 actuator?? will it cause damage to the turbo / engine?? and how much boost could i run? and wot power figures should i expect?
cheers
With a fmic + bov + r33 turbo, id get it tuned then u cud run probably as much as u wanted, but id say to keep it safe keep it around 1bar for racing and just normal say 10psi for daily driving! Yes the r32 actuator goes onto the r33 turbo no problems aswell.
Actuator regulates the boost level, (ie rb25 actuator = stock 7psi, rb20 actuator = stock 10psi)
rb25 turbo is just bigger than the rb20 turbo really.. series 1 r33 turbos are the strongest (but usually are older remember). Actuators generally come with the turbo, if not put ur rb20 actuator on there (or maybe do that anyway...)
rb25 turbo = $400 (+ install.. $100-200)
FMIC (inc install) = $700-1000
So your looking $1500ish for it all done, if your exhaust is done ull notice one hell of an improvement :)
Actually i wouldnt run too much boost with the rb25 turbos. S2's have a plastic compressor wheel, and both have ceramic exhaust wheels, so its possible to drop the wheels off still. I was running 16psi constantly with my S2. Before i had it tuned, and with a small boost leak which lost a lot of bottom end i still ran a 13.0 @105mph with a 2.1 60ft on crappy tyres. That was in a 180sx, but a R32 gts-t isnt that much heavier, so you can beat most commodores if thats what your worried about. One of the biggest differences was getting it tuned, top end was a little better, but the most noticable was normal driving and the mid-range... fuel ecomonmy was much better also. As someone said before, your clutch will go quickly, mine lasted about a week
Series 1 turbos are not really any stronger as both s1 and s2 have ceramic turbine wheels which is the weekest part of both turbos. The S2 has a plastic compressor wheel which gives better responce.
Is it possible to put a t28bb onto an rb20det?
If so, would it be better than the rb25turbo?
Sorry, i must be a dumbass.. i still dont really understand the role of the actuator.. i understand that it regulates boost.. but i dont understand how the rb25 one is better than the rb20 one. How do they differ?
A t28 smaller than the turbo you have already got.
Its not a mater of one actuator being better than another. is all the actator does its push the wastgate open once a certain amount of boost is reached. An rb25 actator is designed to open when it sees 5psi where as a rb20 actuator will open when it sees 10psi.
cheers
You are running a bit lean there, the power must of came down a bit once the fuel pump was changed. I had 137 rwkw but was running flat 14 AFR and after the fuel pump change it went down to 130 but very rich. The car was still pretty stock then.    :O
I'm fairly sure you want to run a 12:1 AFR
putting a T28 from a S14-S15 on a RB20 would be useless exercise.
it will cost more to fabricate a new flange for your manifold and I'm not so sure if would actually be called an UPGRADE.
actuator.
the RB20's don't have a boost controler at all.
the factory boost setting of 10psi is set that way due to the spring that is in the actuators diaphram (that round part at the front)
that spring is hard enough to keep the wastegate closed enough to provide the engine with 10psi of boost.
The Rb25's have a solenoid that controls boost. this solenoid is controlled by the ECU.
so the actuator diaphram has a spring in it that is weaker than the RB20 one.
the spring alone can only hold 7psi.. and the ecu/solenoid combo work together to provide more if needed.
so when people upgrade their RB20 turbo to an RB25 turbo, because their stock engine doesn't have a boost controller, they use the RB20 actuator.
this means that they can still get 10psi with no other boost mods on the new bigger RB25 turbo.
as Sydney kid said earlier, the RB25 turbo will flow (meaning produce) 10% more at stock 7 psi than the RB20 turbo does at 10 psi.
so even if you use the Rb25 turbo and it's own actuator, at 7psi you will have more power than with the rb20 turbo at 10psi.
but use the rb20 actuator on the Rb25 turbo so you have 10 psi on that as well and you end up with a 25% increase in power/flow at same boost on the new turbo.
does that help?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
