Hi everyone
Just wondering if anyone can tell me what price ide be looking at for a colour change to my car? Any one got any places to recommend for a cheap respray???
I know there was an ad posted on here for cheap resprays but it was closed. Any suggestions?....cause im sick of white!
https://www.sau.com.au/forums/topic/71925-price-of-respray/
  • Replies 78
to change the color of your car, and do it properly will cost you in excess of 6k engine needs to come out, just depends on how keen you are. i have a white r33 and if i was ever gonna get a respray i would just get a nice pearl into the white to make it look better and stand out more.
But then again thats just me, go black, then you can see how bad the panels mite be and you can wash it and it can be dirty straight away :)
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1326001
ill second that comment around being black and dirty the next day... gosh it gives me the shits.
not even next day, i just washed the car and then drove it, pull on to the side of the road where its gravel, and the dust i created just covered the car... what a waste of washing..
(i know, 'dont pull over on the dirt then', well i had to pull over somewhere!)
shaun.
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1326530
yeh colour change resprays start to get pretty expensive, our shops prices starts around 7k for respray and thats only an outside respray without a colour change, but thats a flawless job
i wouldn't recommend it unless you have heaps of dosh, or you have a painter mate
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1326839
shaun.
Don't ya just love it. I've gone one step further and got white rims on my black car, now there is a washing nightmare :D
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1326889
i had a spray job that was off the gun when i had a front end prang. It was totalli shit. Very nasty and wouldnt recomend it as it looks like it was done with a spray can. A year later when i bought my body kit, my uncle did a whole repsray with 5 coats + 4 coats of clear for 1600 :D Gettin a respray is BS unless u know sumone in the game hey.
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1326977
if you know someone who can pull and off the gun finish it will always look better then a buffed one
my car has been painted twice one by my uncle and once by MC racing and both time they have been off the gun.
buffing cuts 30% of the shine and you will always have to buff it to keep it looking good.
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1326996
yep thats all this car needs as it really is in good condition apart from a few scratches here and there...... so any sydney recommended people that do this type of thing? and what happened to the guys from this forum offering such a service?
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1327128
i got a quote from jetspeed for around 3500 for same colour respray.
I've heard that you can slightely change colour of your car somehow with not too much difficulty. ie, my car is silver series 1.5 r33, i wanted to get it the gunmetal series 2 colour...is there a way to do this without all the hassle of a 8k paint job??? Mind you its by no means a show car or anything, but i would like it to look good
https://www.sau.com.au/forums/topic/71925-price-of-respray/#findComment-1327288
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
