Originally posted by akeenan
*** id like to take a minute and remember my old trust exhaust ...full 4 inch pipe with the good old 5 inch tip id belted out 108 db ...that lasted about 1 month :mad:    ****
thankyou.
Akeenan, i know this is kinda off the subject, but have a R33 GTS-T and just ordered a Trust Power Extreme II turbo back with a 3.7" pipe... it comes with a baffle that sits in the back box, but now i'm worried that it will be EXTREMELY loud... i live in a high residential area with lots of old folk who may become scared... is that what you had? Any baffle? :eek:
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-114890
  • Replies 64
Oh dear. The EPA and the elderly are certainly going to be unhappy. Is it unbearably loud? why did you take it off your car? You had a cat back didn't you?
I've ordered a turbo back, with cat replacement pipe (yeah yeah i know i shouldn't :uh-huh: ).... this will surely only be louder?
-marcus
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-115162
my car got complianced with that left on it...i wanted it left on so the place i got it done at just said ok....they knew it was illegal, but they didnt seem to care....
anyhow i got busted with it about 1 month later so we took it back to the joint and they replaced it for free with something legal....ive got no idea what it is all i know is that it is only 81db now and its got a 3 inch from the cat and a 3 inch tip...its all stainless steel. They said that my current exhaust is 100 times better than the other one but I would trade anyday!! however I would only get busted again...:mad:
and the dudes kept it and that was the last i saw of it
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-115168
  • 3 weeks later...
So i've just got my exhaust... only the cat back section at the moment; the front pipe is on its way.
It is a 4" TRUST Power Evolution, basically straight through all the way (there is a pic on the last page i think). It is loud. Witout the baffle i couldn't drive around; it was so bloody noisy. Has an awesome note though; without the baffle sounded like a racer.
With the baffle in (after 1 day) it is not too bad, but will still be a fair bit above the legal limit i'd guess... Akeenan, must be the same one you had. Posted some pics too
-m
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-129137
I received an EPA notice in the mail back in October for excessive noise.
Someone else was driving my car when they passed a copy car who had pulled someone else over. My car pulled into a driveway a couple houses down as this was his destination.
2 weeks later, I received the notice and had 30 days to have the car tested for sound. Somehow, my car had to come in at less than 90db at 4200rpm.....
How did a car like mine pass I hear you ask??? It's a long story but let me tell you that a dead stock R33 GTR including exhaust reads at 89.2 db and not all Midnight purple R33 GTRs are the same as mine :P
Oh and BTW, they don't give you certificates with smiley faces and passes to stick to your boot anymore. I don't even know where I put my copy of the statement which I sent to the EPA.
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-129600
Turtle, it is a bit low, but i have no problems on speed bumps so far coz my car is stock ride / stock wheels.
Leewah, hopefully i won't have to visit the EPA with the baffle in, but if i do i'd better find a friend with a silver series 1 GTS-t :P
https://www.sau.com.au/forums/topic/7194-epa/page/3/#findComment-130021
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
