i know this sounds like a stupid question but how do you adjust and check the timing on RB engines
like i know that the CAS is what adjusts it and stuff but how do i check the timing
i have a timing light that connects to the leads usually, and you all know that RBs dont have leads so how do i check the timing
and where do i connect the timiing light too ect.....
all help is appreciated
thanks in advance
matt
https://www.sau.com.au/forums/topic/72217-how-do-you-adjust-the-timing/
either:
a) at the back of the coil pack loom there is a white wire that you are supposed to use for timing. hook the timing light over it as if it were a spark plug lead.
B) take out coilpack number one and take off the the rubber bit at the bottom of the coilpack that goes over the spark plug, then put a lead from the spark plug to the bottom of the coilpack and hook your timing light up to that...
there is a black loop at the back of the cam cover that you use insted of the spark plug leads.
be careful reading the timing as there is sevral marks on the cover below the crankshaft wheel that line up with the timing belt mark.
if unsure just take it to a midas and they will ajust it to whatever you want for $15 bux
Not sure about skylines....
Normally u connect the CAS gun to a spark lead.
Aim the light @ the timing adjustgment screw (look around the timing belt bottom of engine area???)
and move the line to advance or unadvance timing...
in the first post i already know how to use and adjust timing just not with coil on plug configeration
and yes i know how to move the CAS to advance and retard the timong have already done that to get the car firing for the first time last night
but i dont know where the sweet spot is thats why i need to know how to!!!!!!!!!!
thanks anyway
no you see that is my problem if you know where forster is you know this is a problem mechanics here are old and basically dont want to touch it unless they have like a greggery's workshop manual for one if you know what i mean (ie.. they wont touch the imports)
thats why this car has been built by me and a mate in the back yard form the ground up
as for the black loop where bouts on the cam cover is it exactley as i have seen no loop on the loom what so ever
and by cam cover are you talkin bout taper covers??? and is the loop supposed to be before or after the ignighter???
matt
either:
:D
This is the safest method. But you don't necessarily need to remove the coil pack's boot to get it to work, in fact leaving the boot in place helps keep the plug lead in contact with the terminal.
Base timing at idle is 15 BTDC.
OK SOO... I CUT THE END OFF A LEAD, PLUG ON CYLINDER ONE SPARKPLUG AND JAM THE OTHER END IN THE COIL PACK ????? IS THIS CORRECT
pretty much
but you should need to cut the lead. i have never cu the leads. just used them as is... :(
You'll be right. have a play... cant really go wrong.. just dont get sparked by the coilpack :( and dont let it zap the motor... although there is no harm in doing so. im sure its not good for it :(
i have a rb20det in a silvia what is the procedure with the timing
ie....
i have the service manual it says to turn the idle screw on the computer all the way down then disconnect the AAC ( ? ) bla bla bla...
can someone post a step by step guide and disregard the "where to put the timing light" ill sort that out??
remind you that i have a rb20 and at the moment have done nothing at all to the timing what so ever just the way that we put the engine and put a new timing belt on!!!!!!!
ok here is my trouble
the manual says that BTDC timing is 15 degrees at 650 rpm thats with air con on
my truoble is that because i have fitted into silvia have removed air con to fit the thermo fans and custom manifold wastegate bla bla...
what do i do the car wont idle lower cuz there is no air con
so what is BTDC degrees at what RPM with out air con????
I've never set timing with A/C on. I think the only time you load an engine is in an auto (stuff it in 'D').
So in short, the answer to your question is 15 BTDC @ 650 rpm
Also, no need to cut the plug lead. Mabe just need to slip the "cap" end of the lead back a bit to expose the terminal better.
but i dont have an auto so do i set the timing just at the normal idle??
plus my tacho is not correct has not been converted for the rb so im blind at the moment just cant afford to get another thing wrong thats all!!
You don't have to have the engine idling exactly 650 - I doubt you could ever make it do that. I know that reading the handset on my Wolf 3D, the revs can vary by as much as 50 rpm aroung the idle point.
If the engine sounds like it's idling at somewhere near the right revs, then you can set the timing. As long as it's not racing or anything. Usually, changing the timing a bit can often change the idle revs anyway, so you'd end up chasing your tail - idling too fast, change timing, idling too slow, change timing...
  • 2 months later...
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
