I've got the following forsale.
Oil filter relocation kit $100 (suit RB engines) -SOLD
Black R32 GTR boot minus spoiler $90 - SOLD
R32 GTR Stock front pipes $50
R32 GTR Stock dump pipes $20
R32 GTR Stock front sway bar $30
Brand new Field One Connector for RB26 ECU $150 (its a wiring harness that goes between the ECU so you dont have to cut up the original harness to install things like a boost controller etc..something like the attached picture)
pm me for more details
Cheers
Could I get a little more info on the Field One connector? Do they have a website? Where exactly does it tap in to the loom (at the ECU I take it from your description)? Some close up shots would be great.
:P
Lucien.
Ronin 09
I dont mind sending the boot to Melb, as long as you pay for freight
lwells
I'll get a digital camera and take a pic. The way you connect it is as follows. The loom connects to the field one connector then the field one connector to the ecu, its a 10minute job.
cheers
Ronin, I will bow out and let you have it. I only wanted it mainly because it was cheap, and because my boot has a couple of holes in it from a wing that I have now removed. I will just weld them up when I can be farked. enjoy the boot :(
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
