I was filling up yesteday and when i removed the nozel, the metal inlet came up a bit with it...hmmmmm, gave it a small pull with my fingers and the whole thing just popped out! There was a black glue like substane that held it in place, didn't look like much there and had deteriated a bit.
So my question, what do i use to glue it back in?
It must be something along the lines of Selly's no more gaps but obviously needs to be petrol resistant. Any ideas?
Thanks... :rolleyes:
https://www.sau.com.au/forums/topic/72328-found-my-fuelpetrol-leak/
yep..'gold'....
the no more nails used on my car came apart 6 months ago! what a joke!!
Anyways, the stuff above looks shit hot and shiny bright, use that...or...
Do what I've done, remove the remnents of gluey muck and that's it. Nice big hole now!!!
Oh yeah!!...I had to change my fuel filter as it got clogged from the goop they used to attach the adaptor and car wouldn't go!!
All ace now, but!!
Well i ended up using the Loctite stuff but not the one pictured above....it was a stip of blue/white stuff that you had to knead together..(remineded me of that redlight/green light chewing gum on Mission Impossible..haha) Cost me 9.99 It is super rock solid and for the first time ever, i got the psshhhh vacuum sound when opening the cap for my next fill. Must have worked!
As for not filling it right up...and crayons n easles....get working on Windows Paintbrush...i wanna know damn it !
Thanks peeps :(
Thought I was the only one in the world that has this problem. Only occurs on track days at Mallala S.A. Thought it was the cap so got a new genuine cap at Nissan. Next track day leaked like a !@#$%. Car is a series II R33 GTR. In desperation did a search of forum " should have done it months ago" and found this thread. I checked the nozzle insert tonite and could not find the movement you all speak about. There is a rubber boot liner that goes around the filler out to the edge of the cover opening. Does it leak from behind this cover where it joins the filler. If so how does this boot come off for repair. No matter what level the tank is at I never get a ssssssh on opening HELP!!!!!!!!!!!!!. Cant keep on affording to pump fuel out almost didnt make it back to Adelaide last track day.
Its the restrictor they put in for compliance , sometimes they fix it with sikaflex , the fuel melts it na then it leaks , common problem with most imports .
You have to take the restrictor out and fix it with a fuel resistent substance .
Same as me dude
Noticed it at Wakefiled park track day doing the hairpin left turn
Only becuase someone saw fuel pouring out when driving behind.
Did the same as, bought the fuel cap...no difference
Anyway, after mine nearly fell out ( a year later of 3/4 tank fills....grrrrrr) i finally did something about it.
There was bugger all gooo stuff holding it in.
I guess when you're a compliancer, you just wack it in and move on to the next car.
So even if yours in in real tight, might have enought goo to hold it tighht but not the full circumfance of the pipe so no complete seal. Mine now has HEAPS !
I fully layered inside the pipe with that stuff, and layered the outside of the restrictor insert......pushed it in REALLY tight ! ..and as i siad, no have the psssshhhh sound when opening. The stuff also says it's fuel/oil proof so hoepfully that's the end of it.
Good luck !
Thanks, for the replies, I will try to get to Abahn to find the miracle loctite blue/white stuff that will stop the 98 octane rooster tail behind my car and get my psssshhhh back. However if I cant get it before the track day this weekend can the compliancing fuel filler restrictor be taken out and the standard fuel cap screwed in temporarily. I cant let the EVO club thats running the track day not have competition.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
