  • Replies 116
Hi, a petty request, but do you have an ashtray? I looking at butchering one for a custom turbo timer placement. Got one?
Cheers
G
Yes, I do. Have a couple in stock. $20 each
Regards
26motorsport
do you have left side aircon vent and space saver wheel? if so, how much do you want for the items. Cheers.
Yes, have both. $190 for the wheel and I throw the vent in plus freight.
Regards
26Motorsport
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
