Don't know if anyone read the lastest Autosalon Magazine, it had a write up on a Skyline here in Perth that a guy's worked on for the last 6 years!
Looks absolutely awesome!! He did a fantastic job of it let me tell ya!!
He's put on a Wise sports body kit, think it has 421 rwkw.
Saw that it had the www.skylinesaustralia.com printed on the back of his car.
Wonder if he is on this forum??
If you haven't seen it I suggest go have a read!
https://www.sau.com.au/forums/topic/72415-anyone-see-gt-n1k-skyline/
Under all that Tupperware it's still a GTS-T no matter how good it looks (and it does)
Couple of R34GTR's for sale here for less money.
Would still be enough money left for a cool set of rims.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=69670
Have to ask yourself which would have the higher resale value in 5 years.
Maybe a bit harsh of me but my opinion only of course
Cheers
Saw it at a cruise a while back ,very nice indeed. Bit too showy and i imagine it would suck it down so its no daily driver but if you like that kinda thing it would be great.
One of a kind is a good thing ya know :(
I've know Nick for a while, he's a really top guy, and put a huge amount of time and money into the car, as he's made it exactly how he wanted it to be. I think the car is great:D
I put the www.skylinesaustralia.com sticker on the back of his car at PAS a few years back.
Cheers
Only a gts-t???? its the ony gts-t, its completely unique, not another one anything like it in aus.
So gotta ask yourself, would you sooner have another R34 GTR (very tasty), or
A one of a kind skyline that puts down enough power to stop all over that GTR?
All hypothetical really isnt it, depends on what you like. Cheapest way to mod a car though, buy one that is already done :) its rarely though that you see one that has been modded this well, ie, no expense spared.
Yeah, has it ever run a time ? All good and well having 945849854rwkw and being a dyno queen, and a show pony, but real 1/4mi. times ?
The car wasn't designed for 1/4miles, I doubt you'd add 200kgs of stereo equipment if you want to go fast:p Besides I didn't see you racing at Drag Combat;)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
