Took the new car to the local dyno workshop and had it tested for hp -psi- and fuel ratios and considering the car is near stock for engine mods I was most impressed it only has a HKs exhaust from the cat back and a panel filter so the average hp was 204hp atw and the air fuel rating was about .7 which is fairly rich and the car was running on stock psi of 7psi of boost, overal I am very pleased with the result...
Next step I would be guessing is to try and locate a HKs dump pipe from the turbo and a big flow cat convertor (having problems trying to locate the dump any ideas) and then some sort of air fuel controller most here seem to use the Apexi range bu I have since found out that there are 2 types to get not sure as to which one will be best suited for me I am only wanting to avhieve about 250hp also looking at fmic
https://www.sau.com.au/forums/topic/72527-near-stock-r33-204hp/
250rwhp is well within reachable relms :P
Dump pipe....even an X-Force 1
Apexi SAFC
Boost controller..maybe run 10psi
& your there!
Even without the SAFC , you could run a few more psi safely as your on the rich side anyway. for about 220rwhp
You might want to have a real close look at an EMS stinger ecu laced in instead of SAFC , it is more cost but also gives you ignition control & would be handy for future mods :(
Cheers
Troy Rep.
wat year is ur car bro? i got a 94 gtst and last time i dynoed it, all i had was 3in cat back, pod and bov and i got 223hp atw, running on standard boost. every1 thought it was pretty good for what it got. but since then got a huge fmic and will be boosted pretty soon, can't wait to get her on the dyno again...
I just went to my local Exhaust shop (proper guy, not a Midas etc) and said "I want a 3" front/dump/cat". The next day a custom front/dump (1 piece) and custom 3" Cat was fitted. It gave me around 13-15hp and drove so much better.
An Exhaust Cam Gear (about $170 delivered from Japan) will give you another 13-15hp and their you have your 250hp with no aftermarket management at all for just another $1,000 total.
The skyline is a late 1994
I thought about the EMS... but I think it is like a full on computor to replace the stock one which I am hesitant about at the moment also I am not sure as to specifics with the computors hardware eg. if the car stock ecu is a 16bit processor and a EMS is only a 8bit then there is no huge advantage... I have been down that track before with computors.. I think I need to be honest with myself as to how much h.p I am really wanting and how much I am prepared to pay for it ( and not just in $$).... I will probably end up just getting a air/fuel, but hey who knows they say a female is allowed to change her mind so I think I will just keep on reading and see what I like, the other thing I have to be mindfull of is having someone local that can tune the things as I have not got a clue...
George spoke to me about the dump that you are referring to and it sounds interesting just have to get rid of the crappy cassette player that is in the car at the moment so money will be spent there first then in about a months time will start modding the motor
For management, have a look at the Greddy E-manage, basic form does AFM intercept, same as SAFC, but for a little more you can get full ignition and injector control = full management.
205 is good, shows all is as it should be especially with 7 AFRs? this does seem a bit high, has it had the fuel pump done? should probably be getting more than 7psi boost too. Front/dump and cat are good ideas for next upgrade.
Oh, and if you are looking for 250rwkw, there is a guy selling a complete upgrade for $4k changeover with stock parts - FMIC, HKS turbo, injectors, fuel pump etc. Check the for sale, it would be an excellent cost effective way to make the car sing
Have previously used a GReddy E manage and was very good it helped out in increasing the Lancer power by 70% in N/A form but not sure if the GReddy and profec unit will be able to get rid of the speed limiter on the car were as the Power FC will be able to get that sorted
What I meant was with the piggy back style comps is that you have to match them up as you want them to work faster or at least the same speed as the factory unit as far as recieving air intake signals and processing them to the ignition/injection... if the factory unit is faster than the piggy back then processing delays means that you won't be getting the possible result .... but hey what would I know that is just my thoughts on after market comps ;)
the PFC is starting to look a winner so far as it will remove the 180klm speed limit, give better tuning/economy and can be tuned here local... now all I have to do is try and work out which model R33 it is that I have if it is a series 1, 1.5, it is deffinately not the 2...
which brings me to another interesting item on the rego papers the car says it is a 1995 model but on the plates inside the engine bay it says 11/94 but I think the bodyshape is very much like the S2 ?
I think I saw somewhere on the site were you can punch in model numbers and up will come details from the factory as to what your car is will try and find that to get more accurate details
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
    • ok. Yea, then I would need to remove the turbo and weld an adapter on to it instead, if I fuc* this one up.
    • No. Only for a standard ECU with/without Nistune. Standalone has no need for it. That's like the 3rd time I've said so.   And as to that sensor linked - yes, it does look like it would be the right one. I've never bothered to see how available they were - just assumed that they'd be hard to find. I think I'd be planning to go Link ECU rather than buy sensors I don't actually want to make Nistune work, if I did not already have Nistune. As you do not already have Nistune, you should realy consider your options.
