Steering wheel vibration
Hi guys, I wonder if any of you had the same problem as what I am experiencing at the moment?
My steering wheel vibrates as soon as it hits 100km/h.
I have done wheel balance and wheel alignment.
My front brake pads are new.
I have noticed that depending on the road surface Freeway I can drive up to a 120km/h and nothing will take affect. Also I have noticed this happens when I accelerate suddenly.
But when I do it progressively the vibrations are not there or are very small.
Mainly the sped is around 100 when it happens.
Is there anything in particular that I am missing that I haven’t thought of? Wy is his happening?
Thanks
al
https://www.sau.com.au/forums/topic/72730-steering-wheel-vibration/
Wierd - did they test drive the car? did you tell them about this vibration? they'd probably be better to ask.
Yes,
They just tell me their people know what they are doing.
Even the other place didn't charge me full price as the wheels were balanced 110%
They have no idea about why this is......
help
I had the same probs you have.The car came with crap 17 inch chromes on and they made steering really wobbly.When I got new tyres put on and went to pick them up the guy marked 2 of the rims front and the other 2 rear.2 of them had buckles so they went on the rear and it was alot nicer to drive.Before it was bullshit at speeds around 100+kph
Now I have Volks on and they are a dream!!200+kph on a track with no wobbles.
So maybe you have slight buckled rim/rims on the front maybe?
I had the same problem with mine, 4 wheel balances and each time it came back! I finally found out that the tyres were really old ( the numbers are on the tyre and he could figure what they mean) and was told that they had probably sat for a long time in the same position thus making them out of shape.
The Car is R33 GTST
It will be one or more of the usual problems;
1. Out of balance tyres (are they balanced inner and outer? Or just one set of weights?)
2. Out of round tyres (easy to check on the balancer)
3. Out of centre wheels (do they lock securely over the hub centre?)
4. Out of round wheels (how is the run out on the inner and outer rims?)
5. Out of balance brake rotors (unusual, but does happen)
6. Worn wheel bearings (jack it up and check the movement, in and out top and bottom)
7. Worn radius rod bushes (you can see it, the rubber is torn and fluid leaking)
After that it gets obscure, eg; worn shocks can cause vibration after hitting a bump.
:rofl:
Just put the new rotors in and the vibration is almost gone.
I Should have just machined my front rotors but few places told me they were under size.
That turned out to be crap as when I took them off they were 29mm.
So in conclusion I spent $430 on front rotors and I didn't have to. But now the problem is gone.
But for how loong as the rotors bed in to the pads ,we'll see!
What is lower steering?
:D
Checked all of the above. Everything is positive.
Just changed new DBA rotors and machined my rears and the problem is almost gone. Still a bit of vibration evident. Only done 20km , will see what happens in the near future....
Al
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
