Hi,
When i first got the car the problem wasn't that apparent but now after a while its gotten worse and worse. It used to only happen when the window was partially or fully down but now occurs when the window is up.
This could be a bit of a noob qestion but are there bolts and stuff to tighten and grease the window bearings or whatever?
Cheers
Yang
https://www.sau.com.au/forums/topic/7293-r33-rattling-windows/
You have to take your door trim off, and you will see where the bolts are to adjust it! Basically there a re a few bolts down the bottom that hold the window in. Check if they are loose, and if they are, then tighten them.
Next
At the top of the door, and in the middle, there are some bolts holding a couple of rails that guide the window as it goes up and down. Adjust them so that the window leans more into the interior than it does now (you will know what I mean when you see it). Dont do it too much though, just a bit, and test it out. If it needs more, do it again, but do it in small increments, b/c if you do it too much the first time, you can break the window when you close it...
I had the same problem with my car(used to rattle like crazy when i sut the door with a half open window), but I solved my problem this way.
Zahos
Interesting... my driverside door has afew rattles when i shut it but my window is actually broken (motor busted i think - known R33 issue), i might take the trim off -again- and check out those bolts. (I've seen em but just didnt think that this could be the problem).
AFter removing the door trim last nite and having a look at the bolts for the windows we fuond there were two main areas to adjust as Zahos said.
Along the bottom middle and top there are a few bolts that simply hold the window in and also hold the frame that moves the window. These can be tightened slightly and it seemed to fix the problem.
Along the top there are two other bolts which can slide up and down and guide the windows movement. These are adjustable however we didn't adjust them.
I'll try post pics tonite.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
