Hi,
When i first got the car the problem wasn't that apparent but now after a while its gotten worse and worse. It used to only happen when the window was partially or fully down but now occurs when the window is up.
This could be a bit of a noob qestion but are there bolts and stuff to tighten and grease the window bearings or whatever?
Cheers
Yang
https://www.sau.com.au/forums/topic/7293-r33-rattling-windows/
You have to take your door trim off, and you will see where the bolts are to adjust it! Basically there a re a few bolts down the bottom that hold the window in. Check if they are loose, and if they are, then tighten them.
Next
At the top of the door, and in the middle, there are some bolts holding a couple of rails that guide the window as it goes up and down. Adjust them so that the window leans more into the interior than it does now (you will know what I mean when you see it). Dont do it too much though, just a bit, and test it out. If it needs more, do it again, but do it in small increments, b/c if you do it too much the first time, you can break the window when you close it...
I had the same problem with my car(used to rattle like crazy when i sut the door with a half open window), but I solved my problem this way.
Zahos
Interesting... my driverside door has afew rattles when i shut it but my window is actually broken (motor busted i think - known R33 issue), i might take the trim off -again- and check out those bolts. (I've seen em but just didnt think that this could be the problem).
AFter removing the door trim last nite and having a look at the bolts for the windows we fuond there were two main areas to adjust as Zahos said.
Along the bottom middle and top there are a few bolts that simply hold the window in and also hold the frame that moves the window. These can be tightened slightly and it seemed to fix the problem.
Along the top there are two other bolts which can slide up and down and guide the windows movement. These are adjustable however we didn't adjust them.
I'll try post pics tonite.
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
