Hi !
Could anyone tell me what turbo this is.
I bought it as a R34 N1 turbo though not sure if it is or not.
I have done a HEAP of searching and have found that 34 N1 turbos should have :
0.60 front
0.64 rear
9 blade rear wheel
No markings on the front compressor housing
These turbos have:
0.42 front
0.64 rear
9 blade rear wheel
No markings on front housing
Does this turbo look like an R34 N1 ?
There is no plaque
On the rear it has written:
0.64 428-2 TR7093
Any help appreciated !!! :thumbsup:
https://www.sau.com.au/forums/topic/73007-help-r34-n1/
Ok I will let you know these turbos are R34 N1 turbine because of the following:
1. it has no markings on front compressor while nismo turbos do ie a/r .60
2. it has nine blades at the back while r32 nismo turbs have 12
3. if it spins really, really, really easily than that means its a ball bearing turbo, while r32 nismo turbos are not.
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1343533
Yeah those three points are valid
BUT
It has a compressor A/R of 0.42 instead of the 0.60 A/r
Apparently all R34 N1 turbos have a compressor A/R of 0.60
The A/R I can see written inside the "tube" part of the compressor housing (sorry not sure of the name of that particular bit of the turbo but where the compressed air goes out of the turbo and off to the intercooler).
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1343625
OK guys
I ?think? I have similar turbos currently fitted to my R32 GTR (only just)
Part Number is : 14411-AA403 (both turbos did have the plaque)
Which according to Nissan are series 3 R34 N1s – with SS internals and BB rollers. They also have 9 blades
BUT
Mine also have a small separator between the rear turbine wheel and the waste gate (which yours do not seem to have – tho the picture is a little fizzy)
I have only just had them fitted and have not had the chance to fire them up yet, so I can't tell you how they will go. I'm waiting for PCF + EBC to be fitted in a week or so.
I'm also fairly sure they are .42 A/R on the comp side (can't be sure and the pics I have do not show it) and they came off an R34 V-spec II AFAIK
I do have a SQ (silly question) Are Nismo and N1 the SAME thing?
My understanding is that there are N1 turbos and Nismo turbos – and only the Nismo turbos have the .60 compressor housing - but I could be making it all up :cheers:
HtH
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1343650
Indeed they are the specs of the 34N1s that UAS are selling
A search of the forum will reveal that there are many types of 34N1, and I have now found that they came out in a 0.42 compressor as well as a 0.60 A/R
Pete you got the ones with the 0.60 compressor which are the ones I was after, so I'm selling these and will try and get some with the larger compressor housing. Either that or I'm also working on the possibility of swapping the comp covers over to the larger housing.
EDIT: have found a pair of 0.60 A/R covers so will see if these fit once they arrive. in the meantime have taken off the market. if they dont fit i'll have to put them up for sale again. here's hoping!! :(
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1344187
yeah no worry ,i lose track of whos who no here sometimes, i have got a another guy down this way chasing the r34n1 aswell
i'm concidering see if there any interest in group buy
as i was talking to turbotec yesterday and
there off the street price is ~$2325ea
if we get a group buy going ~$2000ea
not bad for such a great turbo(the turbos that won targa this year i believe)
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1344473
Flicking through an old mag and they made mention of N1 turbos and NISMO Group A turbos. Both available through Nissan apparently.
Saying the N1s were same size as standard with better flow capabilities obviously and that the Group A turbos were identified by there larger 0.6 compressor housing. Maybe this is the confusion or group A turbos are something different again?
https://www.sau.com.au/forums/topic/73007-help-r34-n1/#findComment-1344537
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
