Adam,
The basic arm is IDENTICAL, it mounts to the same place, they are both interchangeable, BUT as Ben says, the rear brakes on the MR are different, they are only 254 instead of 290, the caliper mounts may be different as well.
The DR rear arms are unique as the HR's are same as MR & I just chucked a pair out yesterday. The original arms off my PNV, gone to the recyclers.
I have a pair of stock HR calipers here as they are very similar to DR. I will check tomorrow if the calipers can be mounted to the DR rear end etc and advise further.
I think you'll find that the DR rear calipers have longers "ears" on them to space further out on the edge of the 290mm disc . I had a DR and MR caliper side by side 4 yrs ago and that seemed to be the obvious difference - aside from DR's larger diametre pistons . I did once see a 280ZX that had the large piston bridge section with the short leg non floating part so obviously can mix and match . Off the top of my head it was a 3/78 build and also had short leg big piston front calipers and the single rear mount R200 diff .
  • Replies 41
faaaaaaaaaaaaaaaaaaaaa out $220.00 for one arm. Shit they're expensive, we chuck stock MR ones out here in Sydney
And my last purchase of a complete rear end minus diff was only about $400.00 and we got brakes as well.
Shit Adam thats expensive!! OUCH even!!!!!
Rear brake pads NFI, maybe speak with Barry or someone similar, cause you can't walk into sprints or repco and get anything for your car trust me, they have no idea what a dr is...
Alternator, either get it rebuilt or bosch one's fit, ask Josh he's replaced his with a bosch one, i just got mine rebuilt seems alright so far...
What motor you end up putting in the car??????
Are rear brake pads available for the DR brakes?  Mine are almost shagged.
Even if they aren't, you can get pads cut to size for about $20. Any place that sells performance brake pads should be able to line it up for you. Just take in your old backing plate for them to use as a template.
Did you end up sussing out whether the DR arms are the same as MR ones? Measure the distance from the bearing housing to the centre of one of the caliper mount holes. Take a picture of it too if you can. Either post it up here or email it to me. We'll sort this out once and for all...
Actually DR30 are same pads as rear disk MR30 and I think same as S14/S15 . Like I said the calipers are almost the same except piston size , leg length and minor variation in cable mount .
Cheers A .
If that is the case, the MR and the DR trailing arms are the same. Hopefully, Adam will do a little measuring and we can put this puppy to bed.
Rear pads are the same as MR30 hatch but different to sedan. If ya want the part number for a alternator I dare say I can have a look at mine for ya seeing as how it's just laying on the floor in the garage.
And geez it looks like jaustech have up'd there prices last one I bought was $170.
Edited by DR JOSH
MR/HR/DR30 along with S13 rears disk pads all same, but MR30 sedans would be a problem as they have DRUM rears.
I finish early tomorrow but I think Adrian is correct as I think it's just the legs, but I will measure mine tomorrow afternoon, as I have both HR & DR rear calipers.
Adam, check the cost of Alternators Vs postage, cause Bluebird (Bosch) are same mounts & I might just have a few laying around.
Cheers
You'll find I'm right because I've been there , yes DR30 brakes bolt up to disk brake A arms with the matching disk . Because the front calipers on DR30's also use larger piston calipers the master cylinder size is larger to cope with the increased fluid transfer volume . You can get these larger 1" bore masters as some 78 model 280ZX's used them .
Cheers A .
Cheers  A .
Only one problem with this theory. All are not as they seem. Only 81/83 models of DR had 1" m/cylinders, all 84/85 models have only 15/16 same as Z31 300ZX.
Reason, the early models had a distribution block on top of the booster and late models had the distribution in the m/cylinder.
If owners of late models want to re make all their brake bundy tube lines, go ahead, the 1" cyl is available from any reputable brake service centre, but you must specify TOKICO as the brand.
As for the rear trailing arm issue, the parts list shows a GT and L24E rear arm, 2 different part numbers. They also list a pre 08/81 arm that is superseded by the post 09/81 arm.
Having said that, the 2 calipers are as disco says, the DR's have longer legs by about 22 odd mm to compensate for the larger rear rotor. 254 vs 290. The mount centres are identical.
As seen in pic below
Cheers,
Dennis
Interesting Dennis , I've never seen a DR30 that had the late type master/booster like late MR30's .
I've got a feeling DR A arms may have slightly different pivots and cross member , no proof just seen people screw it up when mixing arms and crossmembers . Grp A cars used unique works parts , a friend has the parts list and diagram and no I cant get at it .
I have DR & HR rear cross members and both are identical, exact same everything, rear trailing arm mounts etc etc.
I have never compared MR to DR or HR arms, but know for sure the MR Hatch rear end is completely interchangeable with the same in a sedan, as I supplied a complete MR Ti Hatch rear to a guy in SA and he now has it in his sedan.
The parts list I have is for R30 82 on, but lists the coupe parts as well as sedan & hatch & van.
I only have DR rear arms here as I never gave it a thought that they could be different. anyhow they have calipers etc attached and they are my spares.
AS for the brakes, I may be shooting my mouth off again, but my PNV is an 84 model and it has the late model m/cyl same as MR & Z31's so I assumed all late model cars would be the same.
I also have a DR TOKICO booster and m/cyl which are the older style as you speak of. I think I took all the bundy tubing off my original MR hatch so I might just do the 1" upgrade as well. Surely it must be better for when I do the GTR conversion.
I have read where they recommend a 1" m/cyl with the 4 & 6 pot AP conversions they're now doing for Z cars.
Geez I must have been tired last night.
The 2 different part numbers for the rear trailing arms are #1 for the L24E Sedan (DRUM brakes) and #2 for GT version (DISC brakes)
I would conclude from this, that all disc brake rear trailing arms, either MR, DR or HR would be identical.
A,
Let's not get into a slinging match with this because it's getting a bit off topic, but as my memory recalls, the Gibson Motorsport cars driven by Glenn Seton & George Fury had very unique works parts in them.
So unique in fact that GMS had to make everything themself as they had little support from Japan as can be seen in the #30 car now owned by Terry Ashwood that ZOOM magazine did quite an extensive article on. The entire rear end is rose joints and bars from memory, to the point that they had to make their own solid 22mm half shafts to handle the power they were putting to the ground.
Dennis
  • 5 weeks later...
Sorry to dredge this back up again, but...
1. Does anyone know a part number / vehicle that I can get a 1" master cylinder off that fits the R30 booster? Sorted.
2. Does anyone have a pair of DR30 rear calipers and discs that they are willing to sell / loan me?
Warning: Long-winded, boring background information below
My DR came with the 250mm front brakes, 254mm rear brakes and a 7/8" master cylinder. I do't know if the importer / other persons took the goodies out of it, but it also had an open diff. I competed in it once (it is a rally car) and the brakes were on fire at the end of every stage. Literally, there was smoke and flames all over the place. The pads were sensational - Mintex 1155 all round - but the brakes themselves were obviously too small.
I got a set of DR30 struts and calipers, and heavily modified the struts, so now I can't go back (not that I would want to), but I still have the small back brakes. Oh, and I couldn't get brake pads in time, so I had to run Bendix (or is it Ferodo?) Advance - crap anyway. By the way, walk into any Recpo or AutoBarnPro and ask for Aussie-delivered Z31 300ZX front disc pads. Identical to DR30 front.
I then competed in it again. Didn't really notice much difference, except that the pedal went down much further, particularly once they were hot. Oh, and I had bugger-all rear bias, so the car just wanted to understeer off the road at any opportunity!
I figured I would start by getting the 1" master cylinder. No matter what I do, this needs to be upgraded. For the life of me, I cannot get it. The biggest Tokico (or any other) one I can get is a 15/16". There is a 1" Tokico master cylinder for the Nissan Patrol (disc/drum), but it doesn't fit onto the master cylinder. Not without some time on a lathe, anyway. I just don't fancy having to machine down something if there is something out there that someone knows fits.
In order to establish some adjustability to the brakes, I am installing a pressure limiting valve. This will only be effective if I can get enough pressure to the rear calipers, so in addition to the 1" master cylinder, I need either a) the DR rear calipers and discs, or cool.gif to gut the bias block, or c) both a and b.
I have a set of 4 piston front calipers / discs, and 2 piston rear calipers / discs off an R32 GTS-T sitting here, but the conversion is just a little too yucky for me at the moment. I can only run a maximum of 15" rims, and while they will clear, I will be forced to use spacers, which will probably then require me to buy another 10 wheels that fit (factory S13 Silvia rims spring to mind). While I may be an idiot, I am not a rich idiot...
Anyone? Anyone? Bueller?
Cheers,
Matt
Edited by Matty T
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
