my r32 seems to not want to idle below 2,000 rpm originally my throttle body would stick when the idle pin was screwed in( too lower the idle below 2,000 rpm) I have replaced the throttle body and it no longer sticks but still sits at 2,000 rpm. I have gone through idle adjustment procedure and the ecu section seems to do nothing on my car and the valve control only lowers it to 1,500 rpm or so. I then cleaned the valve as suggested by others this seemed to work for a little while(sat at 1,200 rpm) as the car warmed up it rose very slowly back up to 2,000 rpm. Please help ps my car was auto to start with but idled at 2,000rpm in park then too.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/
check this thread http://www.skylinesaustralia.com/forums/sh...ead.php?t=69151
seems like this is fairly common, mine does it aswell. im gona fix the air regulator soon
im pretty sure the air regulator is my problem cos if i take it out for a drive and it really warms up the idle eventually falls down to about 1000. I haven't fiddled with my screw yet but i will once i get to to start idleing around 1000 to get it down to 750'ish.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/#findComment-1344500
From memory, the resistance (ohms) between pins 1 & 2 (the top 2) should be 0 when the throttle is closed.
A quick check would be to remove the plug while the engine is running, and short the 2 pins on the loom side with a paperclip. If the revs suddenly drop, then you need to adjust the TPS.
https://www.sau.com.au/forums/topic/73198-r32-idle-problem/#findComment-1345737
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
