This is a general question but more so in regards to adjusting the handbrake on R32's. My handbrake is loose on my R32, basically meaning when I pull the handbrake up the shoe in the rear drum drags while moving rather than locking it up like it should. The main reason for wanting to do this is mainly for drifting.
In order to get rid of the slack do people adjust the handbrake at the rear shoe and readjust the handbrake cable as necessary? Or find that they can just get away with adjusting the cable?
Cheers,
https://www.sau.com.au/forums/topic/73295-adjusting-handbrake/
well mine was slack so i tightened it up under the glove box so it only took a few clicks to lock but even now it still won't lock up even if i yank it, i didn't realise there was another adjustment i could make so i guess i better get under the car and have a look on the weekend!
Based on what mr rbman has said, plus the manual also says you need to adjust at the shoe, it'd be best to do it once, do it right? I'm keen to hear how you go cause mine neeeds a tighten too, but is way at the bottom of the to do list! :rant:
Cheers
Mark
try a search on this... for a more definate answer
if you remove the rear wheel, there should be a rubber plug on the rear discs (both sides)
rotate untill you find the thingo doobie, and u shud be able to adjust it there...
then u fine tune it under the handbrake boot (inside the car)
the most efftive way to adj. ur hand bake is from your REAR DRUM, on R32 gts-t type M it uses rear drum disk system, this allow the handbrake to use the drum and footbrake to use disk, anyways to adj. rear hand brake ............
step 1:
take off rear wheel
step 2:
inbetween the wheels studs, there is hold with a rubber cover, to cover it so dust and dirt won't go in side, this hold will let you have access to the drum brake
step 3:
rotate the rotor till the hole is pointing at 6 o'clock
step 4:
stick a flat head screw driver into the hole, now you should be able to turn the spring that connect to the drum pads, this way it will enlarge to pad so that there are less distance from pads to drum, this will greatly effect the power of you hand brake.
ps: turn the spring up will enlarge the pads diamiter, turning it down will make it smaller..also easyer if you take the rotor off
hope that helps
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
