  • Replies 1.8k
Posted Images
Hi Guys,
I believe I have caught up with everyone's emails.
One of you guys mentioned on the last page that boost was dropping off at top end.. If you experience this then it is unlikely to be the controller but something else. Evidence of it being something else builds when you try one or two controllers which give a problem and then the turbotech as well. Although different controllers might 'seem' to present a diffent problem, it is more likely that different controllers exaserbate 'your' cars's problem differently. Maybe leaky or tired turbo, loose clamps, brittle or cracked hoses etc...
Well, i better go make some more controllers for all the SAU orders that have come in the last two days...
Cheers
Mark
The turbotech boost controller definitely tails off with my rb20det turbo.
HOWEVER, the rb20det turbo in its tailing off state (12 down to 9) is making 176rwkw. The turbo has reached its power limit. I can adjust my actuator all the way out and the stock turbo will make 1bar+ in the mid range but as soon as peak power approaches boost will ALWAYS tail off to 9psi no matter what.
Prior, the rb20det and the same stock rb20det turbo was able to hold 1bar using the adjustable actuator, yet only made 165rwkw.
I didn't have the turbotech at this time to test unfortunately.
There is nothing I can do to get this rb20det turbo on the rb30det to hold boost.
A friend put it on his VLT, it too dropped boost to ~11psi or so.
He ended up breaking his stock actuator fiddling, replaced it with an aftermarket adjustable item. It now holds boost much better but STILL tails off. He suspects its his 2.5" exhaust.
2.5" is too small. I run a 3" with a crappy dump pipe courtesy of a so called 'Performance Specialist' *see advert*.
I think the only way to go is 3.5" or 2 x 2.5".
The bloke with the VLT did say it was better than his GFB bleeder.
Edited by Cubes
My turbosmart and the one I got of Mark dropped off. I have read the discussion on this and have blocked off the tubes that run to the factory solenoid. This will fix the boost dropping back to 10 psi
The rb30det is in an R32 so the boost control method in those is basic. They simply run a line from the comp cover to the actuator, you place the boost controller in the middle.
My problem is the turbo is too small for the motor, it makes its peak power at 4400rpm! :P
I'm bolting a cheap Vg30 on now to keep me happy until I bolt the xr6 turbo on around xmas.
To all of those still waiting i have just recieved mine today and will be fitting it this arvo or tomorrow. Will add pictures once installed so people can see how i installed it to my R33. Hope it is as good as it sounds.
I got my boost controller on friday, installed it today, didnt touch anything on the controller at all. Reaches 9.5 - 10psi (too busy watching road just in case) and drops back down to 7psi :s
ill get a couple of pictures one of the controller installed, and the other is the line that the boost guage feeds off. The car only has a catback exhaust (hence why i just put it on and didnt adjust it)
Checked everything and even set up the controller so it was up the right way to make sure that the spring and ball bearing weren't getting caught up anywhere and still no difference.
I get 1.2 bar whether the controller screw is barely even wound in, being heldin place by the locking nut, or if I wind it in a bit too.
Hoses are all connected properly and doesn't appear to be any leaks.  I'm at a loss now, a few people have looked at it and my installation seems fine.
I'm still trying to track down a bleed valve to see if it works correctly with my install. I've emailed Mark for advice on whether or not it might be a faulty unit and have heard nothing from him. Does anyone have a number for him or anything? I just want to get this sorted out.
LOL :lol:
These valves work completely opposite to conventional bleed valves.. Fully wound in is ZERO!!!
with the hose coming off the boost controller to the left, did you take the little metal restrictor thingy out of it (or replace the hose) ?? I had the same problem with my first boost controller cause of that.
I went through some posts before this and found someone mentioning that, took out the little restrictor peice, havent been able to test it myself though because my gf was driving the line around last nite.
Hey all this sounds very good for the price :D
Im just wondering if overtime the spring can become weaker and affect your boost?
Whats the biggest spike any of u have gotten from this?
And so it does remove the lo boost hi boost thing so u get full boost were u would normally get lo? (as in a r34 and r33 i think)
tnx for any help :(
mark's service is fantastic. paid for it friday arvo received it today, considering it was a long weekend im impressed. havent tested it out yet but will let you fella's know (going on a sr20). recommended seller
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
