  • Replies 1.8k
Posted Images
just bought one tonight... whats a good boost level to run a pretty much stock rb20det??
So did you get the one with the 1mm hole in it? Thats the best one is it?
I have a turbosmart manual boost controller I scored off a mate, are the Turbosmart ones better then the $25 item?
How do they compare next to the Turbosmart item?
Is this type a bleed valve boost controller? Because if it is I would say the ball and spring type would be far better.
Edited by daxter
A couple of pics installed on my MR2. Not sure if its right but...seems to be spiking. Could be the way i sealed off the stock solenoid lines.
Hey,
I just got my turbotech controller from Mark off of ebay (whitie_bear on ebay) and my controller doesnt have that tiny excess pressure hole drilled in the back like this one does!!!!!
Isnt that going to highly affect the performance of the controller, i have tried to contact Mark but still no reply, im sure he is busy but this is very annoying to me!!!!!!!!!
Hey,
Are you sure you even brought it from Mark? When I brought mine from him his eBay name was simark87? Mine does not have the hole either and it works very well.
hole or no-hole better/worse is still up in the air a little. If it works good on your car, great. Go with it :) but don't write it off just because there is no hole. Try it first.
i drilled a 1mm hole in my mbc and i have noticed if i accelerate slowly but still let the engine rev right out boost will slowly climb up to 15-17psi and hold there but if i smash the loud pedal staright to the ground boost will shoot up to 13psi and hold there.
got me confused...
anyway.. mine is set on the GTR to 10psi and its feels pretty good. its something like 9.5 but spiking a little.. full boost earlier..
still waiting for the S14a to come round and install on that :P
also has anyone had an issue with this controller..? eg. overboost dramatically.. clog up..kill turbo? etc?
Edited by markimak
i've never had an issue with it. it always holds boost perfectly.
there was one stage where i had heaps of lag, but that turned out to be my cat. changed it, problem solved.
i'm still happy with no hole. since there's no lag, and response is super quick, i'm happy to leave it alone.
so how did u find hole vs no hole? did u do the r34 yet?
rather than reading back thru 72 pages, can someone who has already read them let me know if its worth running them on r33 GTR at 19psi?
what turbos u got. hope u dont wanna run 19 on the standards..
ive heard of people running 24psi and over on these. so year go for it.. :P prob contact mark first.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
