hi there,
im from NZ and happened to come across your site and find it really interesting that you all know this much stuff. Now im a noob at this but im looking at dropping my 98 R34 with King lows and putting a set of 19" Eurohart C Form from Racing Hart on it. they are 9 on the back with 275x35.19" tyres and 8 on the front with 235x35.19".....you guys know ur stuff so do u think this would be ok? any problems that i may find, im in the process of doing it up now it has a C West wing at the mo and when i get the wheels and springs i think i will then look later on at maybe a bomex body kit.
What do you think?
btw: you guys have harsh rules but man your rides are phat :)
https://www.sau.com.au/forums/topic/73384-typical-kiwi/
wiked ride IanH....that car is smokin, so 265 would be better didn't know about that speedo thing thnx man.
thnx RHETT yeah, i found that place too but i couldn't find as much knowledge and info as i have seen in your forums, so ill probly stick around here a bit, i am lookin at different mags today so hope to have something rollin on my car soon but ill show pics :)
i have tiptronic, still drifts ok though, have a boost tap but the car doesnt like going over 1 bar...is that a problem? how can i fix it? and i may look at Tein platforms....are these ok shocks for the R34? instead of kings?or should i stick with the kings? man i really appreciate your feedback guys ;) maybe i could catch up with some of you when im in oz around Sept..Oct
https://www.sau.com.au/forums/topic/73384-typical-kiwi/#findComment-1348578
are you sure 19" could fit? over the weekend i had to do a suspension check since petrolium jelly started to ooze out of the front right suspension arm joint..eek :rofl: however since the wheel was off ithought i might try and see if the old supra 20" rims would fit, stud pattern is the same however the wheel would of never have fit with the nissan suspension strut coming out and over the wheel with only about an inch clearence with the old stock 17" wheel. I beleived that 18" was as high as you could go......am i wrong?
https://www.sau.com.au/forums/topic/73384-typical-kiwi/#findComment-1348691
It doesn't like going over 1 bar because the stock turbo should not be boosting anywhere near that level. It is absolutely at its maximum efficiency at 12psi. You should lower the boost to 12psi and you will find you will make the same power, smoother and no more boost/fuel cuts.
https://www.sau.com.au/forums/topic/73384-typical-kiwi/#findComment-1348795
Hey RyanN yeah, they seemed aiight to me, i had them on this morning but not lowered and it seemed to be ok, the guy at the mag shop hasn't said it wouldn't work with that set up, he was the one that suggested it so i hope it will be fine :rant: else i will have to look at some 18's if i must cause i want it lower...but couldn't i just take that plastic stuff thats inside the wheels arches out aswell or is it best left on?
as for your advice on boost NJR thanx man, it seems to like it at 12 so i think ill leave it there, with my new wheels on anyway i doubt im gonna want to burn much rubber hahaha
i got a pic with them on for u 2 look at and give me an opinion if you like on what you reckon....the 3rd pic is sumthing i put on to see if bling was the thing, so let me know if u like them
https://www.sau.com.au/forums/topic/73384-typical-kiwi/#findComment-1349693
Got them on my car.....man im stoked it looks bloody good :rofl: nice 19's and king low's, now all i need is the body kit but thats $2k away so ill wait on that, next is a Bomex front and carbon fibre bonnet, i also got a carbon fibre GT wing with the wheels and low kit....geez what a nice gf i have hehehehe......ill have to get it fixed to the car soon and sell my C-West wing now hehehehe, pics will be up tomorrow when i get the camera out, its raining here so no time......is there a place on these forums that peeps show off their rides? cause i luv my R34..... :D
https://www.sau.com.au/forums/topic/73384-typical-kiwi/#findComment-1357504
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
