Guys Im into drift and need to install a new turbo (and a few other things) to get a nice 200Kwrw, just woundering what other people have done? what brands/turbos also what boost they are running at with stock internals? what problems you have all had with bigger turbos? also himount or lowmount? I drive this car every day and use it for drift so I need some thing that has good responce
New to skylines aust. so hey all!! :rofl:
White R32 Gts-t m-type coupe
PALADN
Full turbo back exhaust
POD
Oil catch can
Mod ECU program (running 10 psi)
BOV
Fiber glass bonnet (black)
https://www.sau.com.au/forums/topic/73442-new-turbo-for-r32-gts-t/
As you are only after about 200rwkw a HKS2510 would be ideal. They are also ridiculously cheap as no one wants them because we all want over 250atw :rofl:
Combined with a new fuel pump, 440cc gtr injectors and a programable ecu as well as a front mount it would be a weapon with good torque (for an rb20) right through the revrange.
Around 16-17psi should see it make a tad over 200 at the rears. With 264 drop in cams you cold expect to see another 15kw atw at about the same boost.
Then i'd be looking at a better exhaust manifold, high or low doesn't matter, provided it flows better than the stocker.
If you eventually want more than 220atw then a larger turbo like a 2530 would be the go.
Hey buddy, i'm in prettymuch the same situation as you, so i've researched all the parts and prices a bit.
That's a decent price for the Injectors. They'll plug straight into your existing fuel rail BUT you will need a resistor pack because they're a different impedance. which I heard can set you back another $20?~ you should be able to find some more info on this on these forums.
For anything up to about 250rwkw i'd recommened you get an R32 fuel pump. It flows 4.5L a minute (Better than the Bosch 040) and you should be able to pick one up for under $200 - it's a straight swap.
PowerFC, checkout www.greenline.jp you can get one delivered to your door for $1050 without the hand controller. I don't think the hand controller is very important, the better tuning places use the laptop as it has more tuning features, so I figure why not save yourself a few hundred $$$.
I found some info on the injectors for you
The transistors in the ECU for RB20/25 are designed to drive injectors with an impedence of around 12-15 ohms. The GTR (and toyota 440cc injectors I have) are 3-5 ohm so 6 resistors are required to splice in between the power wire to the injectors and the injectors themselves. The ECU then switches to earth on the other side of the injector to operate the injector.
It may work for a while without the resistors, but the eventual result is fried ECU
Then you are able to get the injector timing and pulse width modified (with an aftermarket ECU like PFC) so the car won't un too rich
For a drop in fuel pump get a walbro. The kit suits r32gtst/s13 as it uses the same bracket in the tank. The r32GTR pump needs the bracket to be modded a bit to fit but isn't too hard. I went the walbro solely because it was new and i have quite a few mates with them and no problems to date. You can pick them up for about 200 bucks.
For GTR injectors 300 is about the going rate, it's also the going rate for rx7 550 cc injectors which are high impedence and will definately flow more than enough. I tend to lean towards the 440 GTR injectors as you can pick up 6 of them easier than 6 rx injectors, dropping resistor is a bit harder to find.
PFC is also a bit harder to come by for an R32gtst, you may have a long wait for one even though they are advertised on Nengun and Greenline. It is possible to re write the stock ecu though with good results or go for another stand alone type ecu such as Haltech or Wolf.
You can safely acheive about 180rwkw with the stock ecu and injectors a new fuel pump
Where would I get a walbro from? whats the flow rate? also the rx7 injectors are they plug stright in or do you need the resistor inline too. where do you get these resistors from?
PFC autobarn has em for 1500 with the hand controller
also if I can get rx7 injectors would they be better than GTR ones?
New to skylines aust. so hey all!!  :rant:
PALADN
POD
Oil catch can
BOV
HKS 2530's are a good turbo for a r32 to wont spool up quiet as quick as a 2510 but they are good for 220 to 230 @ the wheels
You'd want the late model series 4 injectors for straight plug in. They are a high impedence 550 cc injector, pink top with part number 195500 1370 i think, some minor shaving of the plug guides is needed to fit straight into the rb20 loom.
Or Series 5 high impedence with part number 195500 2200 which are also pink but have a slightly different plug requiring a bit of modification of the injector loom to install the new plugs.
Walbro pumps can be picked up from a heap of places. I got mine off ebay. You can also get them at http://www.importbitz.com/enginenew.htm . They will quite happily flow enough fuel for over 250 atw.
If autobarn has a pfc with hand controller for 1500 to suit r32gtst in stock then get it now, seriously. You won't see that every day. You could probably get it cheaper online but as i said earlier, you will have to wait. Make sure it isn't for an r32 gtr or r33gtst as they aren't compatible.
As you are only after about 200rwkw a HKS2510 would be ideal. They are also ridiculously cheap as no one wants them because we all want over 250atw :)
Good advice, but its 200rwkws, and its a pretty easy formula. GCG hi-Flow or 2530. Sure a 2510 will do it with a bit more bosot, but are harder to find, and id sacrifice 10rwkws at 3500rpm to make 10rwkws more at 5,500rpm but with 2-3psi less boost:)
If you grab the 2530, get the Pfc, (mine took 10 days from placement of order...lucky? Maybe) and stick with std AFM, injectors etc, just throw a fuel pump at it. See what power it makes before the injectors become an issue...then if you want more power then worry about the injectors, you may find with a rising rate reg you will get over the line?!?!?!
If you have a nice IC, filter, clutch , exhaust already then its not hard to get the 200rwkws. If your car is a stocka then it can get expensive:(
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
