i need a new bleed valve, the one i have spikes to much due to crappy make haha, so is there any suggestions on which ones are good makes, ive herd that turbo smart are quality, and does any one have expierience in this area so i know what to look for in a new one
thankx
https://www.sau.com.au/forums/topic/73904-bleed-valvesboost-contollers/
thankx
All bleed style boost controllers suffer from this problem. we have also found that boost drops off in top gear. Best way to solve this problem is to install Turbosmart E'Boost. E'Boost 1 is on special for $600 as new E'Boost has been released. They work prime with no spiking or boost bleed.
Mate, honestly I wouldn't even bother with a bleed valve. They all spike and suffer when trying to hold boost up the top of the rev range. Save your pennies and get a Turbo Smart E-Boost. They're on super sale at the moment for $600.00.
Remove the faulty bleed in the mean time.
Adrian
yeh i was looking at them...they look pretty neat and have heaps of functions hey.
They have heaps of safety features which eliminate overboost, as well as excellent wastegate controll. you can keep gate closed for longer which brings boost on harder & faster. there are also outputs for launch control or N.O.S etc
Hey
what type of bleed valve do you have at the moment, so we no to stay clear of it :D ???
BTW is there a electronic boost controller.. that doesnt have heaps of functions and is realy cheap ? Paying like $400-600 for a boost controller is like half the cost of an ecu :rofl:
I've just picked my self up a cheapo ball and spring type bleeder. Its not actually a bleeder, the knob adjusts the tension held on the ball.
Should work well as I've had a similiar type before which worked really nice.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...ssPageName=WDVW
its a TURBOXS boost controller, from SPEEDWORKS.....hey ZYMOTIC do you recon that boost controller is quality or dodgy???
Don't they have a little allen key in them to adjust spike?It may pay to have a look and if it does have a fiddle.
Hey
what type of bleed valve do you have at the moment, so we no to stay clear of it ;) ???
All styles of bleed valve are ugly. We are a turbosmart agent, there product is good but still suffers from boost spike. its just how bleed valves work. Im not sure what type of ecu you can buy for $1000, but if it controls engine management & boost, i suggest you buy it. ive been selling Haltech & Microtech for three years & they require stand alone boost controllers as an addition. Apexi ecu have boost control features , but by the time you pay for it, then upgrade air flow meter, you are spending good money. Trust me, E;Boost controllers are worth every dollar. Customers i have sod them too were the same as you until they drove the car after i fitted it, they were very impressed,
check out the article on autospeed.com.au and do a search on 'audi boost', i think it is a norgen setup boost controller.... i have one on my car and it NEVER spikes and has a wastegate creep.. costs $100ish and works perfectlly!
Sounds like the go. How controllable is the wastegate, do you controll it with Ecu?
there are basically 2 knobs... the first controlls boost and the second controls creep... mine is under the bonnet but you can mount them in cabin if you like..
It takes a while to tune but once it is it controls boost perfectly. i have never had boost spike since..
If it works its all good, but you have too compare apples with apples. Boost spike & creep are most evident when you revue a dyno run or drag run through a data logger. you would probably be suprised with the results.
i also have to knobs, but they say one is for coarse boost increase and the other one is for fine boost increase????
maybe the fine one is for creep?
I have one the same as yours maccaz I dont have problems with boost spikes had it tuned at Ice Performance boost holds pretty well I run 10.5 pounds drops off to 9.5 by redline but Ice Performace said this is pretty good and even the electronic boost conrollers do that to a degree and yes they did tune the boost while on the dyno. They said Unless you have something like that (while pointing to GTR with a huge turbo) an EBC is not really worth it.
This type of turbo xs vavle have a ball and spring design so that the wastegate does not open until the set boost level is seen (no wastegate creep) this results in faster spool up. I have the brass part of the controler open by half a turn and then fine tune the boost with the top blue part.
Its interesting that yours spikes and mine does not.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
