I have noticed on my R33 that once I am over around 90k's the steering is very heavy, even on gradual bends. I am running 235's on the front, but while stationary the power steering is light.
I assume the R33 has speed sensitive steering, does anyone know if its programmable? It just seems WAAAY too heavy around 90-110 for high speed cornering ( I guess its calibarated for skinnier tyres really).
Ta
Conrad
https://www.sau.com.au/forums/topic/7413-power-steering-speed-sensitive/
I thought at about 60km/hr the HICAS should kick in and cause the rear wheel to act in sympathy with the front, providing a 4WS situation. After checking alignment etc, check you have sufficient power steering fluid, not enough will make it feel heavy, but you would expect this to be all of the time.
See'ya:burnout:
but is the steering speed sensitive (eg reduces the power steering assistance as you speed up so its not too light at freeway speeds) ?
Slayer,
Yes, I believe that it works this way, otherwise it would be too flighty at high speed. Have you driven any other GTS-t's to compare it to. Your steering may be heavier all of the time, but it might be more noticable at high speed. I'd still suggest checking alignment and power steering fluid.
See'ya :burnout:
I just got Bridgestone Potenza G3's put on all 4, and I was getting the alignment done and they said there is a problem with the alignment in the passenger side rear, they had to keep it on a slight negative camber... He said it may have been bumped into a curb in Japan or something, and this could inturn affect high speed cornering. He recommended the best thing for me to do was speak to whiteline about a bush kit which may fix the problem up a bit...dunno, will c
Paul Paul
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
